Transmission Worries.
Old Nov 13, 2014 | 02:53 PM
reggieh11's Avatar
reggieh11
hey I have a 2004 6.0 Powerstroke with 175,000 miles on it. I recently installed an S&B cold air intake, custom 4" turbo-back straight pipe exhaust, bulletproofed, and now I just got a SCT X4 Flash programmer. I was wondering if I would be able to run the performance tune without having to worry about the transmission which is stock. or is that too much power for it?
Old Nov 13, 2014 | 03:12 PM
Jmoen7's Avatar
Jmoen7
Others will be more specific, but i'm fairly sure you're no where near the hp needed to kill your transmission with a tuner and those upgrades. Stock should hold near 600 hp at the crank or something, not 100% but ballpark
Old Nov 13, 2014 | 03:26 PM
reggieh11's Avatar
reggieh11
okay and do you know if there's any mileage increase on the performance tune or do you only get that on the street and tow tunes?
Old Nov 13, 2014 | 03:43 PM
Jmoen7's Avatar
Jmoen7
Depends on your right foot, can be higher mileage usually, and can also be considerably less if you like your turbo to stay around 20 psi haha.
If your cruising the highway like normal you should see a better mpg than without the tune.
Old Nov 13, 2014 | 03:52 PM
reggieh11's Avatar
reggieh11
Okay and this is my first tankfull with the programmer so I've had a lead foot like most people would. But next tank I'll calm it down and see what I get
Old Nov 13, 2014 | 04:00 PM
Jmoen7's Avatar
Jmoen7
Not really a point in spending a whole tank checking MPG, if you have a 200 mile trip or something check it out then and you'll get your numbers
Old Nov 14, 2014 | 11:17 AM
reggieh11's Avatar
reggieh11
Normally I avereraged 15.5-16 milers per gallon and with the tuner and a lead foot I got 15.1 running the street and performance tune. Just going to drive normal on the performance tune and see what I get
David Fehir
Feb 26, 2019 08:46 PM
rodneywar
20
Jun 17, 2012 07:13 PM
oubeta
6.4L Power Stroke Diesel
Jul 28, 2010 02:20 PM
Packrat Super duty
Feb 7, 2008 06:41 PM
Square Grouper
Sep 7, 2005 12:26 PM
