1959 Ford F500
Old 11-13-2014, 11:15 AM
Charles Melck's Avatar
Charles Melck
Charles Melck is offline
1959 Ford F500
This is a South African built ford f500 truck I bought from a farm manager but traced to the original owner just a hill away
These are the before pics prior to a light resto I kept the patina but needed to do a bit of cutting and brazing, work done on rusted doors and corner bits
came out well, now to get it registered for on the road use
I am informed that the wheels are "widowmakers" not knowing what the implication thereof is.
There are a few other bits and pieces i am looking for if anyone has it lying around they are the side steps .
I have not seen many of them on the road still in south africa but this one was built in south africa according to the vin no and plates in the cab yep we are right hand drive here.
Before
Old 11-13-2014, 12:11 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
I'd suggest doing a Google or Bing search using the Firestone RH-5° trade name and widow maker common name. You'll find a lot written, and pictures, on FTE as well as on other truck sites. Stu
Old 11-13-2014, 07:40 PM
spurredon's Avatar
spurredon
spurredon is offline
Very cool truck and great pics. So glad you are trying to save it.
There are several places that offer some aftermarket sheet metal, here is one for example. Ford - Ford Pickup Truck Door Step Plate - Left - Macs Auto Parts They are a good company to deal with from my expirience. They also have the riser piece that goes above it.
Enjoy your truck
Old 10-31-2020, 05:17 AM
Ls1500's Avatar
Ls1500
Ls1500 is offline
Looks familiar
Old 10-31-2020, 09:12 AM
JohnNewb's Avatar
JohnNewb
JohnNewb is offline
That would be a 1960 model here by hood and grille. The "widow makers" refer to split rims. Rims with a separate retaining ring. They could blow off during inflation or tire mounting, injuring or killing the person. Most tire shops in US won't touch them. Some old shops still have the metal cages outside they used to inflate the tires.
Old 11-06-2020, 08:09 AM
Geno C's Avatar
Geno C
Geno C is offline
widow makers don’t have a retaining ring. They are split in the middle. A split side ring wheel can still be serviced by many shops today
Old 11-06-2020, 07:57 PM
JohnNewb's Avatar
JohnNewb
JohnNewb is offline
I sit corrected. I had to Google it to see the difference. Crazy design. Were trying to make it easier to fix a tire on the roadside?
Old 11-07-2020, 10:36 AM
Geno C's Avatar
Geno C
Geno C is offline
I suppose that was possibly part of it. Not really sure what the engineers were thinking. They really aren’t a problem design until you take into account corrosion
Old 11-07-2020, 10:52 AM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
No to fix/replace tires period, mechanical tire changers were few and far between when these were designed and they all done manually.
hamptonsgarage
04-23-2019 12:48 AM
transam525
09-20-2014 06:27 PM
MrMach71
15
03-22-2012 06:50 PM
jmadsen
06-01-2011 12:34 AM
Duke58f100
1947 and Older Ford Trucks
05-10-2008 06:11 AM
Quick Reply: 1959 Ford F500
