Cleaning windows
Old Nov 12, 2014 | 03:48 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Cleaning windows
I cleaned my windshield and side glass 3 times carefully, very proud.
Then I took my truck out in the sun and there are streaks all over!
How do you guys clean your windows? any easy miracle products out there?
Getting frustrated.
Old Nov 12, 2014 | 03:54 PM
My Old Tools's Avatar
My Old Tools
Add dishwasher detergent to your bucket. It stops streaks.
Old Nov 12, 2014 | 03:56 PM
49f3dls's Avatar
49f3dls
Contact lens cleaner. Takes the realty stuck on bugs off and no streaks. Expensive but I always keep the expired left over from my daughter. Works really well
Old Nov 12, 2014 | 04:04 PM
CharlieLed's Avatar
CharlieLed
Sprayway aerosol glass cleaner is the best. Go into almost any glass shop and you will see cans of it sitting all around the shop. The wife does art glass fusing and she uses it exclusively. Works great on the inside glass of vehicles.
Old Nov 12, 2014 | 04:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Remember "Glass Wax" from the old days? (Used it to "frost" windows for Christmas) It has a bit of clay in it, actually polishes the glass. I need to find some, the original isn't sold any more, but Gel Gloss sells nearly the same thing.
Also, use newspaper (black print only) instead of paper towels.
Old Nov 12, 2014 | 04:51 PM
AXracer's Avatar
AXracer
Old army "GI party" method for streak free windows or mirrors definitely works: spray bottle full of white vinegar with 1 or 2 drops Dawn (no more or will streak), use wadded up newspaper pages to scrub and polish dry. Change portion of wad in use and switch to new wad frequently. 6-8 pages to do windshield: 2 turned 3-4 times to scrub each side (in and out) with solution (4 total), 2 to polish each side streak free. 3-4 pages for each side window. Do not clean hot glass or in sun! Also do not rub newspaper against light colored upholstery fabric.
Old Nov 12, 2014 | 05:04 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Thanks, these are some great ideas
Old Nov 12, 2014 | 05:09 PM
Tedster9's Avatar
Tedster9
Ammonia cut with water, seems to work fine. Windex is basically ammonia and blue dye. One recipe is Ammonia, rubbing alcohol, cut with water and a drop or two of dish soap.
Newspaper works well for windows. They sure as hell aren't any good for reading.
Old Nov 12, 2014 | 05:30 PM
ChuckRob's Avatar
ChuckRob
I don't know, the wife always does the windows for me and they always just sparkle.
Old Nov 12, 2014 | 05:43 PM
AXracer's Avatar
AXracer
Please send her to my house. Thank you in advance!
Old Nov 12, 2014 | 05:58 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
after she leaves AX place you can send her to mine
Old Nov 12, 2014 | 06:00 PM
B/B ford's Avatar
B/B ford
Clean & Classy
I think we have the solution!
Old Nov 12, 2014 | 06:53 PM
Jag Red 54's Avatar
Jag Red 54
Can she cook too? Jag
Old Nov 12, 2014 | 07:02 PM
old_dan's Avatar
old_dan
Easiest way....use windex, but use plain old newspaper to wipe the windows with. The newsprint is a little abrasive on a very small scale and the paper absorbs better that any paper towel. It's best to avoid the pages with color printing.
It might work even better with some of the solutions recommended by the other guys, but the newspaper is the key.
Old Nov 12, 2014 | 07:50 PM
49f3dls's Avatar
49f3dls
She is going to be a very busy woman traveling the USA for FTE windows!
