Radiator Options
Old Nov 15, 2014 | 04:44 PM
jowilker's Avatar
jowilker
Ryan, May I ask why?
Why is spending $300.00 on something that your truck does not need the best $300.00 that you spent on your truck?
I don't wish to offend, just interested why?
John
Old Nov 15, 2014 | 07:06 PM
rmk73's Avatar
rmk73
No offense taken Joe. I meant that in the context of how well it fit and required nothing but just bolt it in. And in the world of aftermarket parts that's kind of a rarity. I got some stuff off trucks in the junk yard like you kind of preach.. but I also like some nicer, upgraded parts in cars and trucks I build as well. So where some ppl would go search junk yard for their yr truck and get everything they can off of it for hopefully cheap prices I would rather get brand new parts if I have the option in some areas of my builds. Just an example of different ways to get the job done I guess.
This radiator is really well done for $300 btw! A lot of buddies have real high end radiators that cost upwards of $600 so I didn't have a problem paying 289 for mine and the caliber truck I'm building here I wouldn't do any less...
I appreciate your point of view and the tutorial kind of comments you contribute on this forum! I have used your instructions and suggestions on some areas of my build for sure. Have good night everybody!
Old Nov 16, 2014 | 10:18 AM
sseebart's Avatar
sseebart
I've been considering a radiator upgrade and have been reading up on aluminum radiators. Most antifreeze makers advertise that their products are safe for aluminum, and I have read that distilled water is important for corrosion resistance.
The dissimilar metals (iron block, aluminum radiator) allows electrolysis, which some counteract with a sacrificial anode (in the cap, at the petcock, etc). Sounds reasonable to me, though I haven't got firsthand experience.
~Steve
Old Nov 16, 2014 | 10:36 AM
Tedster9's Avatar
Tedster9
Steve, that's what I was getting at. It may be the latest and greatest coolants spec'd for OEM vehicles are a result of that, because aluminum has taken over in the last few decades. Maybe the type of inhibitors and/or the amount are different not sure on that.
Old Nov 16, 2014 | 01:10 PM
37 Ford guy's Avatar
37 Ford guy
Yes, the aluminum radiators are nice but definitely require extra attention! They are not forgiving of any shortcuts! First, make sure your block/heater core is completely flushed of rust or other debris. When you install the radiator, you must attach a ground wire from radiator to chassis to help prevent electrolosis. The green coolant is fine but only use distilled water for any additional filling!! You must also flush & change coolant yearly, if it lasts that long.
azhoser
Arizona Chapter
Sep 5, 2013 10:21 PM
K9sicem
Dec 5, 2012 06:04 PM
John & Old Ford
13
Jul 28, 2012 11:04 AM
mattsf-100
Mar 24, 2007 02:36 AM
66sprintw53
May 3, 2004 10:13 PM
