White smoke even when warm
Old Nov 10, 2014 | 12:10 AM
obs96SE's Avatar
obs96SE
Ok so recently my 96 psd decided it wanted to start puttin out white smoke even after the motor warmed up. I have replaced o-rings and valve cover gaskets before not too long prior to this incident. Is it true that if you dont use the ford motorcraft o-rings any of the others will just junk out within not even a thousand miles? Just wondering what the hell is going on with it. It actually runs great only time you can feel a miss is if I'm sittin in the driveway in park and rev it to around 1500 or a little shy of that. Thanks in advance.
Old Nov 10, 2014 | 02:14 AM
stainlessstroker95's Avatar
stainlessstroker95
Are you saying you just replaced injector o rings with no ford/alliant ones? If so then it sounds like you found the problem. The rev test like you did is one way to see if the injector o rings are bad. Also check your fuel filter and see if it is black. If the o rings are bad you will start getting oil in your fuel.
Old Nov 10, 2014 | 06:00 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Just plain old generic o-rings will not work in anything fuel or HPOP related. You must get the ones designed for that specific application.
Old Nov 10, 2014 | 03:46 PM
obs96SE's Avatar
obs96SE
I did order specific o rings for my injectors yes but not from ford dealership they were aftermarket ones which at the time i thought were fine. But after the fact of ordering them I started readin some online forums where people were sayin only order the ford ones...
matowns21
161
Jul 22, 2012 10:11 AM
dbf74
Nov 25, 2010 10:10 AM
14psd
Sep 10, 2010 09:18 PM
eckart
May 13, 2004 01:08 PM
donblue
Sep 23, 2003 10:25 PM
