trans related chirpping
Did you install a new clutch and bearing when you did the swap? did you grease the input shaft that the bearing rides on?
I have seen faulty bearings right out of the package.
Best way I found to tell for sure is to put the truck in the air on all 4 corners with jack stands and have someone climb under it while it's running and engage the clutch back and forth.
The_Josh_Bear
06-06-2010 02:40 PM
Nightrain
21
11-19-2007 01:59 PM
Katfish1989
02-16-2007 07:31 AM
F150Lariat79
09-13-2004 08:40 PM
kacpam
05-09-2003 10:12 AM
