trans related chirpping
Old 11-09-2014, 09:06 PM
Landfill90's Avatar
Landfill90
Landfill90 is offline
I recently swapped my 96 f150 from a 5 to a 4 speed and now the dang thing started making a noise. I thinking it is the throw out bearing but I don't really know how to tell.
It does stop and change pitch as I press the clutch.
Old 11-10-2014, 08:44 AM
Mike1's Avatar
Mike1
Mike1 is offline
Did you install a new clutch and bearing when you did the swap? did you grease the input shaft that the bearing rides on?
I have seen faulty bearings right out of the package.
Best way I found to tell for sure is to put the truck in the air on all 4 corners with jack stands and have someone climb under it while it's running and engage the clutch back and forth.
Old 11-10-2014, 01:01 PM
Landfill90's Avatar
Landfill90
New clutch and bearings while I had it out from under the truck. It's been a little while now but I'm pretty darn sure we greased it. And it seems to come and go as it pleases like this morning it didn't make a noise until I was sitting with it idling.
Old 12-29-2014, 03:59 AM
Landfill90's Avatar
Landfill90
problem found
it was a bad throwout bearing it seemed to have got stuck burned up the clutch and where a good grove in the pilot shaft sleeve
Old 12-29-2014, 12:42 PM
Mike1's Avatar
Mike1
Mike1 is offline
Well that sucks, but at least you found the problem before real major damage was done. Good luck with the new one.
The_Josh_Bear
06-06-2010 02:40 PM
Nightrain
21
11-19-2007 01:59 PM
Katfish1989
02-16-2007 07:31 AM
F150Lariat79
09-13-2004 08:40 PM
kacpam
05-09-2003 10:12 AM
Quick Reply: trans related chirpping
