Sponsored by: Real Truck
Dually Conversion
Old Nov 7, 2014 | 03:07 PM
AMARON's Avatar
AMARON
Dually Conversion
Hi there, I have 2000 F350 / 7.3 that I would like to convert to a dually. Im wondering if the brakes ( master cylinder and hydro boost) need to be up graded as well or if they are fine as they are ?
Old Nov 7, 2014 | 04:22 PM
SuperDutyScaler's Avatar
SuperDutyScaler
The brakes and hydro boost is all the same, all you need is to change to the dually rear axle and rear leaf springs and bed sides. O and the front wheel winders
galaxy S4 using IB AutoGroup
Old Nov 8, 2014 | 04:45 PM
AMARON's Avatar
AMARON
That's awesome, thanks
Old Nov 8, 2014 | 07:29 PM
SuperDutyScaler
No problem
Old Nov 8, 2014 | 08:50 PM
speakerfritz's Avatar
speakerfritz
you also need spacers for the front to push the front wheels wider so they line up with the center line of the rear dual's.
becareful on how you do this.....if you swap rear ends...be advised that 04's and earlier fronts are 8X170s, 04 and earlier rears are also 8X170's but 05 and later rear duallys are 8X200.
ideally, you would want all the rims the same so you can rotate them easier.
Old Nov 9, 2014 | 06:49 AM
MDSuperDuty's Avatar
MDSuperDuty
I completely agree, but the funny thing is that according to the manual when rotating you only change side to side not front to back......
You would however need two different spares.
Old Nov 11, 2014 | 01:05 PM
SuperDutyScaler
On the dually you just rotate the rears left to right. I guess having dual aluminum the inner would corrode like crazy?
Old Nov 11, 2014 | 01:13 PM
MDSuperDuty
I think it has more to do with the fact you can't see that wheel so why waste fancy materials on it.....
The fronts are polished on the convex side whereas the rear is polished on the concave side. So if you flipped them they would just be crummy on the other side. I guess if you had all black steel wheels you may be able to rotate them normally.
Old Nov 11, 2014 | 02:14 PM
sgarder's Avatar
sgarder
AMARON, is your truck 2wd or 4x4? If 4x4 make sure gear ratio is identical to front axle.
Old Nov 12, 2014 | 02:03 AM
speakerfritz
normally, duallys come with steel inner rims even if the outer are alloy.
the reason for rotating rears inside to out is due to the inner tires wearing more than the outer tires due to the curve of road surfaces.....the inners carry more of the load on a curved surface.
and yes, the polish surfaces of the rear and front on alloys are opposite.
Old Nov 12, 2014 | 06:06 AM
hodge5's Avatar
hodge5
My dad had his 03 converted. The brakes were fine. He kept the front wheels stock. It looks different, but he didn't want to spend the extra on it. I don't believe that there are any consequences, other than not being able to rotate from front to back. He's driven it for 10 years now converted, and towed some fantastic loads.
The local Ford dealership converted the Sterling 10.5 from single to dual hubs, and the body shop did the bed work.
As far as what Speakerfritz shared, dad only drives 3,000-4,000 miles a year. We haven't seen any consequences to the tires.
fordman400
Mar 13, 2013 01:07 PM
Brown Falcon
Oct 19, 2008 05:35 PM
SillyValleyF250
Jul 22, 2008 01:06 AM
Mikey85
May 15, 2006 09:27 PM
Diesel Driver
Jun 23, 2004 02:17 PM
