Help...Crank is locked-up!!
Old Nov 5, 2014 | 09:57 AM
Memphis_Sean's Avatar
Memphis_Sean
85' F150 w300 and 4-speed: I started an earlier thread about changing my clutch. Well, after removing/re-installing my flywheel...to change my pilot bearing and rear main seal (RMS)...the flywheel and crank are locked-up...I can't turn the crank from the front crank pulley.
I'm thinking the flywheel bolts are too long and are hitting the block, but their the same ones I took out...do any or all of the bolts take a washer or is there a spacer or something I'm missing??
Old Nov 15, 2014 | 09:46 AM
The Frenchtown Flyer's Avatar
I would start by backing off all the FW bolts a couple of turns and see if it frees up.
Old Nov 15, 2014 | 10:00 AM
Memphis_Sean
UPDATE: For some reason two of the bolts are about 3/16" longer, and when torqued all the way down prevented the flywheel from turning. I ended-up replacing all of the flywheel bolts w/some new ARP Bolts. All good there...clutch is finally done!
mr lucky
Sep 5, 2022 10:35 AM
pascalhorse
Jan 21, 2018 09:57 PM
Memphis_Sean
37
Nov 7, 2014 09:25 AM
Chickenguts
General Diesel Discussion
Mar 2, 2009 02:36 AM
gustaf-dgm
Oct 30, 2004 01:19 PM
