Rear End Size?
Old Jul 16, 2003 | 11:12 PM
sharpshooter's Avatar
sharpshooter
Rear End Size?
I am trying to find out what size my rear end is on my 1984 F-150 and the decal inside my door reads "18" by the axle marking. Can anyone tell me what size rear end I have?
Old Jul 16, 2003 | 11:35 PM
82F100SWB's Avatar
82F100SWB
Rear End Size?
You have a 3.08 geared 3750# Ford axle, most likley a 8.8" due to the 3.08 ratio, 9"ers are usually 3.00, both have the same weight capacity though.
Evan
Old Jul 17, 2003 | 10:34 PM
steve83's Avatar
steve83
Rear End Size?
9" gears aren't available in 3.08 ratio, so that limits it to the 8.8".
Old Jul 31, 2003 | 12:35 AM
figmo's Avatar
figmo
Rear End Size?
I have an 81 F-250 and also a 2003 F-350. The rear end ratio is on a metal tag attached to one of the bolts on the rear end pumpkin.
Old Aug 1, 2003 | 03:58 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Rear End Size?
If your bolts are on the back of the rearend then it's 8.8", on the front then it's 9".
Old Aug 2, 2003 | 02:56 AM
fishmanndotcom's Avatar
fishmanndotcom
Rear End Size?
An 84 F-150 with a 302 and a 9"?? haha, ya right. My 150 with the 351W had the 8.8" in it!
I garauntee it is the 8.8"
-Jason-
Old Aug 3, 2003 | 12:53 PM
steve83's Avatar
steve83
Rear End Size?
I've worked on an '86 EB Bronco with a factory 9". That's the last year they were used because of ABS in '87.
Old Aug 3, 2003 | 06:46 PM
MW95F250's Avatar
MW95F250
Rear End Size?
The '84 in my sig has a 9". I'll have to go and look up the axle code to decode the ratio.
Old Aug 3, 2003 | 07:07 PM
85F_150driver's Avatar
85F_150driver
Rear End Size?
I have the door code 18 axle under my truck. Its a 3.08 8.8 open diff. Hope answeres the question.
Old Aug 3, 2003 | 07:30 PM
MW95F250's Avatar
MW95F250
Rear End Size?
Mine's code 14.
Old Aug 3, 2003 | 07:33 PM
steve83's Avatar
steve83
Rear End Size?
14 is an open 3.00, which was only available in the 9". What's on the F-250?
Old Aug 3, 2003 | 07:36 PM
MW95F250's Avatar
MW95F250
Rear End Size?
The F-250 has a Sterling 10.25 and a 3.55 ratio. Axle Code C9.
Old Aug 3, 2003 | 07:42 PM
MW95F250's Avatar
MW95F250
Rear End Size?
What do you have in the Bronco??
Old Aug 3, 2003 | 08:02 PM
steve83's Avatar
steve83
Rear End Size?
The axle I built from junk parts that you can see in my signature link. I've stayed with the original 3.08s because I have the lowest granny gear available (NP-435), so the hi ratio and tall tires (32s) give me a cheap overdrive with no problems towing heavy stuff. Maybe if I ever get enough spare cash to swap in a ZF, I might go a LITTLE lower, but I doubt it.
rlpatte
Mar 27, 2015 10:45 AM
awq134
2009 - 2014 F150
Dec 25, 2014 01:50 PM
mrrish79
Oct 22, 2013 02:02 AM
67Duffy
Sep 15, 2007 03:21 AM
