harmonic balancer/timing mark
Old Aug 3, 2003 | 07:26 PM
rbthayer's Avatar
rbthayer
Question harmonic balancer/timing mark
I pulled a 460 out of a 1984 f-250, block date is really a 1979. It is a external balance motor. I rebuilt the motor put a roller timing chain in it. Put in as straight up timing. Dots are aligned cam dot down crank dot up. Put timing cover on. Then install harmonic balancer and timing marks on balancer opposite side of timming poniter. Pointer is on pass. side. Harmonic balancer marks on driver side. I bought a new balancer thinking the balancer had spun, but new balancer was the same. I never check this before rebuilding so I don't know if it was like this before. Has anyone seen this problem before. Thanks for any help.
Old Aug 3, 2003 | 07:35 PM
steve83's Avatar
steve83
Was the one you bough specifically for the '84 engine, or was it a generic 7.5L balancer? The EFI version might have had the pointer on the other side.
In any case, make SURE you have #1 @ TDC and make a new mark on the original balancer, and use that to set time.
Old Aug 3, 2003 | 08:06 PM
rbthayer's Avatar
rbthayer
The motor was a carb. motor from factory that year . It's TDC and I made a new mark. It is just something I would like to know why.
copen93
Nov 25, 2014 09:08 PM
MrRogers
Jun 9, 2010 05:58 PM
70T351W
May 4, 2006 07:05 PM
CJ7
Nov 25, 2003 05:42 PM
Dave
Nov 26, 1999 07:00 PM
