Sponsored by: Real Truck
Someone please HELP
Old Nov 3, 2014 | 07:46 PM
FordChyanne's Avatar
FordChyanne
Someone please HELP
I have a 02 f250 superduty 7.3, picking my girls up from school today pulled up to line put my truck in park and it just stalled shut off. I tried to start it batteries are strong but the wait to start light does not turn off and will not fire up. My husband checked fuses reset the fuel shut off switch on passenger side and notta. The fuel pump is getting power but he's stumped. Please help and I'm sorry if I left something out, if you need more info please ask. Thanks for ANY help.
Old Nov 3, 2014 | 07:55 PM
Hotrod70d's Avatar
Hotrod70d
Was the cam position sensor ever replaced it will shut truck off with out notice .. Its a recall item from ford if ur truck hasnt had it changed it should be free . Its 1 10mm bolt. 5 minute change. Aftermarket ones are junk .. Need ford replacement
Old Nov 3, 2014 | 08:07 PM
FordChyanne
Sorry correction
My husband said that the fuel pump is not getting power unless hot wired and the wait to start light does not go off. Sorry
Old Nov 4, 2014 | 05:57 AM
redford's Avatar
redford
FTE Leadership Emeritus
Did he check the inertia switch?
Old Nov 4, 2014 | 10:23 PM
rkmason's Avatar
rkmason
Make sure it has plenty of oil the injectors are powered by oil pressure
Old Nov 5, 2014 | 09:40 AM
DND58's Avatar
DND58
Did the WTS light staying on just start? Recheck fuse #22, with a meter. Do you know anyone with a 7.3 to try PCM swap?
Old Nov 5, 2014 | 11:01 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Fuel bowl heater fuse
The fuse as mentioned above is the #30 under the steering wheel. Remove the cover under the wheel (4 flat head screw type plugs). Black box.... remove the cover and there are the fuses. Its going to the the #30 fuse which is going to be a 30amp fuse. The inside of the fuse box cover will show you the location of #30. If its blown then unplug the fuel bowl heater first ( Pop hood and the round canister on the top center of the motor is the fuel bowl. The top will have a black cap. On the back towards the bottom of the bowl will be a plug. Unplug it from the bowl. ), reinstall new fuse and start. I would check this first. I believe that WTS light not going off is a indicator of a blown fuel bowl fuse.
Never herd of that with a cps. More than likely thats it.
Don't waste your time swapping out PCMs if anything get a code reader on it.
skidmarks82
1997 - 2003 F150
Dec 22, 2015 06:57 AM
crc4x4
Sep 4, 2012 03:25 PM
Glock
1997 - 2003 F150
Jan 17, 2009 01:41 AM
BoostRetard
Apr 11, 2008 10:39 AM
dtucker1971
Nov 22, 2000 09:45 PM
