Sponsored by: Auxito
Truck Won't Start
Old Dec 17, 2008 | 07:39 PM
Glock's Avatar
Glock
Truck Won't Start
2001 F150 5.4L
Truck won’t start the motor cranks over but it does not start. I checked the pressure on the Schrader valve and it had no pressure when I pressed the release valve on the fuel rail. I also checked inertia switch with an ohmmeter and it had continuity between the two contact tabs. I tried smacking the tank with a rubber hammer and tried holding the shift leaver in park while trying to start and had no luck.
Old Dec 17, 2008 | 08:07 PM
n5926g's Avatar
n5926g
Looks like you have no fuel pump...Check the circuit,and be sure that all fuses/relays are in order.After verifying that,look in the FSM,and find the fuel pump B+ lead(wire) locate it,and check for voltage with the ignition switch on..if its there,youve likely got a pump thats "gone south" if theres no B+ at that point(in reference to ground) somethings open between the feed line,and pump.....
Old Dec 17, 2008 | 10:06 PM
Wilber15's Avatar
Wilber15
Just use a test light at the inertia switch. switch your key to the ON position and check for power at both sides of the switch during pump prime. if you're hot on both sides, it's a pump.
Old Dec 18, 2008 | 08:04 AM
projectSHO89's Avatar
projectSHO89
Check to fast-flashing THEFT light first. If solid for three seconds (valid PATS proveout), then check fuse F10 under the hood and the fuel pump relay. Failure of either will cause no power to the fuel pump circuit as checked by Wilber15's suggestion.
Steve
Old Dec 18, 2008 | 07:20 PM
Glock's Avatar
Glock
I checked the inertia switch on both sides and it had 11.8 volts on both ends but the voltage only holds for about 1.5 seconds. I tried to siphon some gas out today but I could not get the hose down in the tank.
Old Dec 19, 2008 | 07:19 AM
laketrout's Avatar
laketrout
I had this problem last week, ended up I needed a fuel pump. There's $800 I wasn't planning on spending this xmas...
Old Dec 19, 2008 | 07:39 AM
projectSHO89
You need a fuel pump.
The 1-2 seconds is the normal pre-start priming cycle.
Steve
Old Dec 20, 2008 | 06:36 PM
mino54's Avatar
mino54
got the same problem WE NEED A PUMP.http://images.ford-trucks.com/forums/images/smil
hi,i am posting this from my post problem because it may help us both i tried start the truck and nothing,i replaced the fuel pump solenoid and no help, removed the solenoid , turn ign key checked for voltage a solenoid pin 65 and 30 got 12 v. at both pins, checked pin 60 to innertia kill switch at pass side panel got continuity, check for volts at innertia kill switch with the ign key on got 12 v for 1 to 2 sec time then drops to nothing never heard the pump humming, took a continuity reading from the innertiakill switch red wire to grnd got very little resistance and good continuity, used a jumper cable
from battery positive to red wire on innertia kill switch(disconnected) and no pump noise or fuel pressure reading at the fuel rails, i think i got a death pump.
more bad news.............the tank is full of fuel.
good news may not rain for a few days.
is it easier to drop the tank or remove the bed
is it normal for the pump electrical supply to turn it self off after 2 seconds of operation?
Old Jan 17, 2009 | 01:41 AM
Glock's Avatar
Glock
Update:
The snow melted so I finely dropped the fuel tank which was full. Two motorcycle tie down strapped across the bottom of the frame under the front and back of the tank with a floor jack in the center worked great to lower the tank. I replaced the whole fuel pump assembly. The truck had a bad misfire after I replaced the fuel pump. I’m thinking what did I do wrong? I’ve replace two coils in my truck so I know what a bad COP fills like. The last time it throw a code it was a misfire on the number 6 COP so I pulled it out and the coil had condensation on it so I dried it off and I have been using that same coil for about two years now.
I tried driving around to get the truck to throw a code but had no luck. The truck shook so bad in OD at about 1100rpm that the gas cap kept popping off this happen three different cycles. After doing a search the only thing that can cause the cap to pop off was a bad gas cap or a bad fuel tank sensor. I tried my original non locking gas cap with I kept when I replace it with a locking cap and had no luck so I’m think I have to drop the tank again. I‘m starting to second guess myself I know it has to be a COP so I pulled a new one out of the glove box, YES I carry a backup COP. I started swapping my backup COP with the number 6 COP then 1, 2, 3, 4, 5, and then 8 I’ll save the number 7 for last. BINGO I had a bad number 8 coil the truck runs great now. So I guess a bad COP can also shake your gas cap off. Now for my new problem I’m down one backup COP.
