ICP or HPOP?
Old Nov 3, 2014 | 11:04 AM
FireBaller74's Avatar
FireBaller74
ICP or HPOP?
In June I replaced the High pressure Oil Pump in my truck. Well, as I was driving to work the truck shut down. I looked at my scan gauge II and the ICP was 300 and the IPR was at 84.7. I know that both are reading wrong, but when the HPOP went out in June, I lost power first then the truck died. This time the truck just died without warning. My question is, is it the HPOP again or the ICP? Thanks for any info.
Old Nov 3, 2014 | 11:59 AM
WatsonR's Avatar
WatsonR
unplug the ICP and try restarting the truck. It will allow the truck to start using the default setting. That may confirm if it's the ICP sensor or not.
Old Nov 3, 2014 | 12:39 PM
dannyboy950's Avatar
dannyboy950
Why do you assume they are wrong? Wrong or not those are the readings the pcm will see and use.
As far as the PCM is concerned that is what you have.
Old Nov 3, 2014 | 08:09 PM
Grant-Dieseltech's Avatar
Grant-Dieseltech
Do you change the oil cooler when you did the HPOP?
travelergypsy
Nov 12, 2018 11:03 AM
wackercattle
Nov 9, 2015 09:07 PM
ArNy64
Jun 4, 2012 10:05 PM
F-250 Super Duty
Apr 10, 2011 08:35 PM
jakemb
Feb 24, 2011 12:18 PM
