ICP Sensor?
Old Apr 10, 2011 | 05:41 PM
F-250 Super Duty's Avatar
F-250 Super Duty
ICP Sensor?
So what goes on inside that little bugger and how does it work? Out of curiosity I unplugged mine yesterday and the connector was covered in oil. So I remembered reading that if that happened it was time for a new one....
Does a HPOP gauge piggy back off that or something else?
Just a few questions I had....
Old Apr 10, 2011 | 06:07 PM
PaysonPSD's Avatar
PaysonPSD
That "little bugger" senses the high pressure oil and sends a voltage signal to the PCM so the PCM can adjust the IPR to raise or lower the ICP depending upon needed fuel reqirements.
HPOP gauge does "piggy back" on the ICP sensor.
If there is oil in the connector it should be replaced.
Old Apr 10, 2011 | 06:10 PM
conkster's Avatar
conkster
Here is a file that shows how the HPOP, IPR, and ICP work and some troubleshooting for the system. I have also heard that you use that location for a HPOP guage.
Hope this helps.
File Type: pdf
Old Apr 10, 2011 | 08:35 PM
JT250's Avatar
JT250
Be sure to be careful with the boot/rubber washer on the ICP pigtail because it can fall off and you will loose it forever like I did and a couple of other guys.
bulla
Feb 14, 2012 05:37 PM
jac08f250
Jul 18, 2010 10:46 PM
Oval_obsessed
27
Mar 15, 2008 07:03 AM
powerstrokeddiesel
Nov 10, 2007 09:35 PM
