hi I have a 77 F-250 high-boy 351 M I have a prob w the power assist I had the ram and the valve rebuilt lines r correct now the wheel turns on its own all the way to the left and snubs out the pump .... the pump is from a 79 F100 ...need some ideas John
The spool, the part I referred to in my previous post, is part of the 3A730 assembly, shown in Number Dummies parts diagram. It is shown immediately above the control valve main body.
Hydraulic pressure leaking past this part will cause the ram to expand or contract causing the tie rod to move left or right.
Reason: clarifying a description
