Transmission ID
Old Nov 2, 2014 | 01:28 PM
FireEngineMike's Avatar
FireEngineMike
Transmission ID
I got a spare tranny with my 1940 1-1/2 ton panel delivery. I am trying to determine if the spare will work in my truck.
The spare's S/N is 99T-435699 which I believe indicates it goes with a 1941 95 HP engine.
01T-7006WG is cast into the driver side. I don't see this part number in the Green Book.
T-8 D1, 4, and W are cast into the passenger side on 3 separate lines. 4//25 is cast in much smaller characters to the right of the W.
What does all of this mean? Is the tranny equivalent to what is in the panel delivery?
Does the PTO just bolt onto the tranny in place of the plate on the passenger side of the tranny or are there internal modifications?
Thanks to anyone who can help.
Old Nov 3, 2014 | 01:31 PM
38 coupe's Avatar
38 coupe
Your spare transmission should work in your panel truck.
The PTO just bolts onto the side of the transmission in place of the plate.
The only things that may be different as far as installing the spare is the rear mount. If your spare transmission came out of a 1/2 ton pickup the rear mount will be different. If your spare transmission came out of a 3/4 ton or larger the rear mount will be the same. You can replace one mount with the other and make no other changes to the transmission.
Old Nov 4, 2014 | 01:33 PM
FireEngineMike
Thanks "38". A friend is picking up the spare tranny this weekend to drain, flush, and have a knowledgeable friend of his inspect the innerds. I'll take a pic of the rear mount and compare it to the truck next time I go over.
Thanks again.
FireEngineMike
Grandadeo
Mar 18, 2019 07:27 PM
roostercrows
1978 - 1996 Big Bronco
Apr 11, 2008 06:21 PM
ojosdestranger
Dec 1, 2004 01:49 PM
86Bronco351
Sep 3, 2003 12:14 AM
wildjon300ci
Oct 12, 2001 01:06 PM
