1978 - 1996 Big Bronco
spare tire carrier
Old Apr 3, 2008 | 07:32 PM
roostercrows's Avatar
roostercrows
spare tire carrier
is there anything to taking the whole spare tire carrier off the passenger side quarter panel? ( you know, the four bolts) is there anything inside the panel, brackets or a mounting plate, or is it as simple as bolting it on and off to the panel?
Old Apr 4, 2008 | 11:40 PM
cfrives3's Avatar
cfrives3
There are nuts spot welded to a plate on the inside of the body. Best access is to remove the right rear tail light assy., then reach up inside. I actually have an inside spare mount that I grabbed off of an 84 goin to scrap. Haven't decided whether to use it on mine or hers with a roll pan, or not at all.
Old Apr 5, 2008 | 08:45 PM
roostercrows
thanks, I didnt think that it could just be bolted to the fender.
maybe Ill look for an inside mount too.
Old Apr 6, 2008 | 02:34 AM
roger dowty's Avatar
roger dowty
not understanding why you have to access the nuts that are welded in place. I just took mine off and on and off etc... very simple.
Old Apr 6, 2008 | 06:40 AM
GlennFordx4's Avatar
GlennFordx4
I just asked the same thing,and was told by the bodyshop that just painted my bronco that you can just unbolt it and told me mine was easy but they have had some be a problem when there is a lot of rust on the bolts and the welded nuts break free.
Old Apr 6, 2008 | 08:49 AM
cfrives3's Avatar
cfrives3
That is exactly why I put that in there. I pulled the carrier off of my wifes EB and two of the nuts inside broke free, one on the top set, one on the bottom set.
Old Apr 7, 2008 | 07:57 PM
roostercrows
oooooooh that makes more sense. I thought the plate with the spot welded nuts on it may rattle and clang around without the bolts in it. So I don't even need to remove the tail light just bolt on bolt off, right?
Old Apr 7, 2008 | 08:13 PM
cfrives3's Avatar
cfrives3
As long as the spot welds are not broke on the inside it should simply unbolt. I didn't intend to give any false info, perhaps I gave too much- sorry.
Old Apr 9, 2008 | 04:33 AM
roostercrows
no-no, thank you for your help.
Old Apr 9, 2008 | 02:15 PM
roger dowty
i'd soak the bolts/nuts with pb before attempting to loosen.
Old Apr 10, 2008 | 07:26 PM
roostercrows
Thumbs up
good idea, I'll do that.
Old Apr 11, 2008 | 06:21 PM
krave's Avatar
krave
the only thing i found was that the bolts on the tailgate held something in place.i had to put the those bolts back minus the bracket
TheSterling
13
May 31, 2018 10:06 AM
jekyll_hyde
Bronco II
May 6, 2017 01:22 PM
Leggeman01
WTB - Parts & other
Jul 10, 2015 06:27 PM
1950FordF1
Jun 19, 2015 06:46 PM
mattsautobody442
13
Jul 15, 2008 12:35 AM
