Radio Blues
Old Oct 31, 2014 | 03:35 PM
Map Man 1's Avatar
Map Man 1
Radio Blues
My radio will not restart when you restart the truck...I have to **** it off and then turn it back on......anyone have a fix for that dilemma?.....Thanx
Old Oct 31, 2014 | 04:18 PM
vastdavidson's Avatar
vastdavidson
Have you removed the cables off the battery for 5 minutes to reset the system?
Old Oct 31, 2014 | 08:30 PM
EO2SeaBee's Avatar
EO2SeaBee
https://www.ford-trucks.com/forums/1...-problems.html
^^^See if that describes your issue. Mine does the same thing intermittently, but a couple quick presses of the power button and it comes right to life.
Old Oct 31, 2014 | 08:36 PM
senix's Avatar
senix
Pulling the cables is not the answer. Hitting the master reset is not the answer.
Perhaps a reflash of the sync may help. I will be taking mine in to speak to them about it.
Challenge is if they can reflash the sync and only that. I would not want anything else touched as that usually results in lower fuel ecomony.
Old Oct 31, 2014 | 10:01 PM
Map Man 1's Avatar
Map Man 1
Sounds like mine.....it does it every time and hitting the power button off and on and it's good to go again.....might try the battery disconnect with head lights on ......sounds funky to me, but so is the radio not coming on...........Oh Well!....You'd think ford would do a recall for the fix.....
Old Oct 31, 2014 | 10:34 PM
n3hcp's Avatar
n3hcp
Mine did that for the first 3 or 4 months after I got it then it magically fixed itself literally overnight. Go figure...
Old Nov 2, 2014 | 08:28 AM
tho2nd's Avatar
tho2nd
Had the exact same problem in my '14 F350.......had the dealer flash the radio and it's worked fine since.
Old Nov 2, 2014 | 12:08 PM
8iron's Avatar
8iron
I just updated the MF Touch but it hasn't helped the problem.
Highboosted
May 10, 2019 11:17 PM
Flexfuel-Dave
1983 - 2012 Ranger & B-Series
Jan 24, 2011 07:34 PM
bf5113
Sep 27, 2006 10:07 AM
bf5113
Jun 30, 2006 11:14 PM
dirtbikeguy2003
Apr 29, 2003 05:38 PM
