Long block questions for a first time engine builder
Old Jan 6, 2015 | 06:37 PM
  #61
ctubutis's Avatar
ctubutis
You'll need to install a socket to connect to and turn the oil pump driveshaft but I forget the size... IIRC there were two sizes used... 5/16 sounds familiar but I'm not at all certain... I've only done it on V8s... google around and you might be able to find it...
Old Jan 6, 2015 | 08:30 PM
  #62
78F150TX's Avatar
78F150TX
Thanks Ctubutis! I'll post what I find and how it works out. Appreciate the help!
Old Jan 17, 2015 | 09:20 AM
  #63
78F150TX's Avatar
78F150TX
So I have the engine all back together and primed it to start with a 5/16 hex head and extension. Thanks to Ctubutis for pointing me in the right direction.
[IMG][/IMG]
Old Jan 17, 2015 | 11:55 AM
  #64
ctubutis's Avatar
ctubutis
Glad you got it figured out
Old Jan 18, 2015 | 11:43 PM
  #65
78F150TX's Avatar
78F150TX
Thanks to the kind and good members of this forum and a bunch of elbow grease I've got old red back running solid. The exhaust leak that started this whole process is gone and a whole bunch more has been done including:
New main bearings (except for main rear as the work was done in the truck)
New piston heads, rings and rod bearings
Valve job
Rebuilt 2100 carburetor
Manifold studs
New battery
New starter solenoid (disappointed I had to replace it. Darn thing only lasted 37 years )
Stumble at acceleration is gone and oil pressure is so much better. My wife says it sounds so good she wants to drive it. Uh oh.
I need to fine tune the carb and timing. I timed it for the first time using my vacuum gauge but I don't think I have curb idle rpm set where it needs to be. I need to bite the bullet and get a tach. Also, it is a bit hard to start so I think I either I'm a little lean or the timing is off just a bit.
All things considered I am very pleased. I couldn't have done it without the kind help and expertise from this site. Special thanks to Frenchtownflyer, Trozei and Ctubutis for walking me through so many steps. You guys are legend.
Old Jan 18, 2015 | 11:57 PM
  #66
78F150TX's Avatar
78F150TX
Here are a couple of pics. First is the lower mains when I pulled them. 2nd pic is my efi manifolds cleaned up and new manifold studs making life easier.
Old Jan 19, 2015 | 04:54 AM
  #67
trozei's Avatar
trozei
Looking good! Glad you got it working again.
78F150TX
15
Jan 24, 2013 07:28 PM
newblder
Jul 22, 2009 07:31 PM
rxfx101
Apr 6, 2005 01:57 PM
TrailRider
Jan 4, 2005 06:06 PM
58shortbed
Oct 17, 2004 03:32 PM
