Long block questions for a first time engine builder
I plan to remove the valves tomorrow and inspect. photos to follow. I'm sure I'll have a ton of questions so bear with me.
To fill the rest of my afternoon, I spent a couple of hours cleaning my Offy C intake and adding a 3rd vacuum port for the Vacuum gauge I'm going to install. I thought about painting the intake, but can't decide on a color so probably going to leave it.
My efi manifolds have quite a bit of surface rust so I decided I want to clean and paint them. After 10 minutes with a wire wheel I decided I would try the electrolysis bath method. The rear manifold has been "cooking" for 4 hours and it looks like it is working great. As soon as I get some photos uploaded I'll post some pictures of that process.
I mentioned in a previous post that i used electrolysis to remove rust from my efi manifolds. Here are some photos of process.
I started with a rusty manifold, 12 gallons of water, 12 teaspoons of Arm & Hammer washing soda, a sacrificial anode (old brake rotor), and a battery charger.
After 3 hours things appear to be cooking pretty darn good.
I let it cook all night and this is what the solution looked like after 20hrs. The solution has cleared up a bit and all of the rust has moved to the old brake rotor.
And here is one rust free manifold.
To give you an idea of how much rust was removed, here is the brake rotor with all of the rust attached.
And here is the same manifold after a fresh coat of header paint.
If you're like me and don't have a blast cabinet to clean small parts up this is a great way to go. I already had the battery charger, rotor, bucket , and paint so I have a grand total of $4.49 invested in the washing soda.
Now I just have to work on the rest of my engine to get it to look as good as the manifolds.
Pretty dirty
#cylinder 1
#cylinder 2
#cylinder 3
#cylinder 4
#cylinder 5
#cylinder 6
Resist the temptation to sandblast any internal engine parts - that's a sure way to early engine failure.
Be sure to remove the cylinder ridge with a ridge reamer. And get one of these Goodson scrapers. It has a carbide edge. The next best thing to milling all the surfaces:
Money well spent
I do have a question for FTF or anyone else with engine building knowledge. How do I tell if I should replace the springs? All of them are quite dirty. I'll look for cracks or stress as I clean them but how else do I tell if they need to be replaced? Thanks.
Springs wear out with age and even more so with mileage. It's up to you whether or not you should replace them, but the basic ones aren't expensive and if you've gone this far...
And you're right I have come this far, I just didn't want to spend money on something I didn't need to. I'll probably pick up a set.
Worn out springs can look just like good springs. They just may have lost some of their "springyness". The best way to check them is with a spring pressure tester. This is usually done at the installed height, or some nominal height listed in the shop manual. Replacing them is not real costly, but I'll let you in on a dirty little secret: The springs on a 300 six are not that highly stressed, since the engine is not designed to rev very high - that is not its strong suit. So they don't usually lose a lot of their spring tension over time. Many rebuild shops know this and instead of taking the time to check all the springs on a spring checker they just add a spring shim on each spring seat - like .030 or so. That takes up any pressure lost to re-doing the valve seats plus a little more for added boost to the seat pressure.
This is OK for a stock build. But when using a performance cam higher spring pressures are often needed. Also, if high revolutions are expected, the exhaust valve retainers (rotator style) should be replaced with intake valve retainers, and a correspondingly longer spring used on the exhaust side.
I hope I didn't muddy the waters for you too much.
I have access to a set of stock springs and keepers that one of my buddies had installed and used for about 15k miles before doing a performance build. I think I'll go ahead and use them now. Eventually I want to take the engine out and do a complete performance build but for now I'm going to keep it pretty stock and low buck.
On a good note all my valves appear to be in pretty good shape. I cleaned the head with oven cleaner (I remember reading that here in at least one thread) and it came out great. Man it was crazy how much carbon buildup was in that head.
I borrowed a ridge reamer at the local parts house and will try cleaning up the cylinders tonight if I can steal some more time.
I'm going to try lapping in the valves tomorrow.
All in all its coming along well and I've managed not to make any huge mistakes yet. I really appreciate all of the shared knowledge and advice.
Cheers!
I managed to get the head all cleaned up and valves lapped. My lightly used springs checked out square. I used the tip from FrenchTownFlyer and installed them with a .030 shim. Its ready to go back on.
That was the good. Now the bad.
Found this when I pulled piston#3....
Holy Cracked Pistons Batman!
I have heard that it's not uncommon for the 300 pistons to lose some skirt but that was more than I ever expected to see. Anyone have any experience with this?
I inspected the remaining pistons carefully and found that the drive side skirts on pistons 4 and 5 are cracked. If I took a set of channel locks I could probably snap them off. I wonder if the missing skirt and two cracked pistons were some of the noise I was hearing at low idle?
To my surprise the cylinders walls were not as beat up as I expected. I used a ridge reamer and cylinder hone to clean them up.
Since I can't afford a complete machining and rebuild right now I found a set replacement pistons on Summit for $78. They should arrive on Wednesday. I'll get them pressed on rods, install new rod and main bearings and hopefully have everything buttoned back up before Christmas.
To the engineers' credit that engine is a very robust piece - reminds me of the WWII B-17 bombers that would soldier on despite being shot to pieces.
Compare those pistons with a new Modular V8 piston. The Mod V8 piston has almost no skirt by comparison. Maybe that's why it doesn't matter at all if the skirts are gone.
That's the model of piston I purchased so I'm feeling better about the direction I'm headed. 😁
