??? windshild trim
Old Feb 1, 2010 | 12:14 AM
mike83f250's Avatar
mike83f250
??? windshild trim
What is the best way, to take the trim off the front windshild.
Old Feb 1, 2010 | 12:40 AM
kermmydog's Avatar
kermmydog
Inside or outside? They are both snap on.
Craig
Old Feb 1, 2010 | 12:35 PM
mike83f250's Avatar
mike83f250
the out side trim is there a spical tool i tried befor and bent the tirm
Old Feb 1, 2010 | 12:43 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Yes there is a special tool, it is a windshield trim removal tool...
Here ya go, it looks like this
http://www.denlorstools.com/shop/images/KD-2038.jpg
Old Feb 1, 2010 | 03:18 PM
Harfend's Avatar
Harfend
I used a similar tool that I got as part of a kit at Harbor Freight. As I recall the trick was to start 1) on the piece along the bottom of the window because that piece of trim was on top of the 2) side pieces and then 3) last off was the top piece. Take your time and work the tool around the connecting clip while appling pressure up and away from the clip. Once you get a couple clips free it is easier to see exaxtly where to press on the retaining clip with the tool and it starts to come off quickly.
I had also bent up one of those trim pieces but was able to fix it with a few careful taps using a body hammer to smooth out the kink in the metal.
No need to use the tool to reinstall. Just replace it in the opposite order of removal and use the heel of your hand to snap the trim back over the retaining clip.
Good Luck!
Old Feb 1, 2010 | 03:22 PM
mike83f250's Avatar
mike83f250
kool thanks, i just need to take off one pice on driver top side corner
Old Feb 2, 2010 | 07:39 AM
Harfend's Avatar
Harfend
Just a quick FYI. I looked at my truck on the way home yesterday and I see the trim is just the oposite of my original post. You need to start removal at the top and then the side pieces. Last off is the bottom.
Good Luck!
Old Feb 2, 2010 | 08:31 AM
mike83f250's Avatar
mike83f250
thanks for the info
Old Feb 2, 2010 | 04:35 PM
evanch123's Avatar
evanch123
I worked at a windshield shop. This is the tool we always used. I set so many ford windshields it was ridiculous. Don't loose those clips either they tend to fly off and disappear. When putting the trim back on lip it on one side and give a good tap. Dont break the windshield I did that a few times. Have fun!!!
https://www.equalizerfusion.com/Prod...ccPt7LTrKLcGzI
Old Oct 11, 2019 | 09:33 AM
Jeffrey L. Johnson's Avatar
Jeffrey L. Johnson
Install
This 9 year old thread was actually helpful....thanks! Removing
the trim was easy as it was falling off due to the rusted/disintegrated clips. New side & top clips were easy to find in the internet. Could only find bottom clips (they are different) on LMC Trucks. I had small pin hole rust spots on the top channel and used POR15 as a temporary (ok, semi-permanent) fix. Oh, the bubbles in the windshield was due to a poor install by a previous owner.
Old Oct 11, 2019 | 09:55 AM
Jeffrey L. Johnson
Install
