Ok Let's Have It Please - Lights?!
Old Oct 30, 2014 | 08:53 PM
Todd Fuller's Avatar
Todd Fuller
Ok my Chilton's Manual is no good on these for my 2003 Ford Expedition 5.4L V8:
1) the backlighting for the Moonroof switch and Vent switch on the center overhead console is out - is there a separate bulb or is backlighting part of each switch?
I actually had the center console down to replace what I thought was a burned out bulb for the right side light. But it was just loose. Chilton's Manual just said to pry off the cover. Wrong! It broke one of the two plastic studs that keep the lens in place. Had to buy a new lens, and then I figured out you have to drop the overhead center console from the ceiling, then, use a T10 star and remove the two star screws to properly install the lens. (thanks Chilton)
2) backlighting is out on the driver door for the 1 and 2 set positions of the driver seat, and, for the the driver and passenger front windows. How to fix? Backlighting for the left and right rear windows on driver door is working.
3) Driver seat AC and Heat is inop, but, passenger front seat AC and Heat works.
4) The side vent windows in the rear, one opens and closes fine, but the other opens/closes very weakly or not at all. I wonder if this is related to the backlighting issue as in #1 above.
I don't think any of these issues are fuse related. I pulled fuse #22 and it is not broken.
Thanks for any tips.
My Expedition is 11 years old with 110,000 miles so some of these backlighting and little gremlin issues are to be expected but I'd like to get them fixed.
Old Oct 31, 2014 | 05:31 AM
alwaysfords41's Avatar
alwaysfords41
#3. Does the switch light up for hot/cold? The seats are fused independently and there is a control module for the seat that also can go bad.
#4 the speed of the window is not related to the back lighting. Lube the motor and linkage assembly.
The back lights are individual bulbs. Buy new switches or buy a package of LEDs and learn to disassemble and solder.
Old Oct 31, 2014 | 09:32 PM
Todd Fuller
Ok thanks so much for the tips. When I looked through the fuse/relay list, it appeared that both front seats were on one relay or fuse.
But the driver seat switch does not light up neither for hot nor cold.
Old Oct 31, 2014 | 10:08 PM
alwaysfords41
I'd go back and check the fuses.
Old Nov 1, 2014 | 03:06 PM
alloro's Avatar
alloro
Except for the headlight and 4WD selector switches, the bulbs are built into the switches and are not replaceable. You have to replace the switches, unless you're real handy with micro soldering very small points.
Old Nov 3, 2014 | 09:46 PM
Todd Fuller
... I've double-checked the fuse/relay list. The driver and passenger climate controlled seats are not fused nor relayed independently
fuse location 18 10A* Electrochromic mirror, Auxiliary A/C,
Climate-controlled seats module,
Temperature solenoid, Turn signal flasher,
Sunload sensor, Electronic park brake
relay coil - page 233
fuse location 118 30A** Driver and passenger climate control seat
Module – page 235
Source: http://www.fordservicecontent.com/Fo.../03exdog1e.pdf
... those are the only fuse/relay locations that reference "climate" controlled seats.
Old Nov 4, 2014 | 05:35 AM
alwaysfords41
Sorry about that, I must have been thinking of the power seat functions. Have you checked that there is power at the switch?
Old Nov 5, 2014 | 12:48 PM
Todd Fuller
Not yet. I'll need to pop the heat/ac driver climate controlled seat switch off and put a multimeter to it to check.
mlammert
Electrical Systems/Wiring
Dec 1, 2018 12:42 PM
bhobgood
17
Jan 20, 2016 04:48 PM
scubydo
Dec 3, 2010 06:04 AM
Pony Boy
1978 - 1996 Big Bronco
Oct 29, 2008 03:28 AM
searay220
1997 - 2003 F150
Nov 28, 2006 03:06 AM
