Oil & Lubrication
2011 Ford Explorer
Old Oct 30, 2014 | 06:58 PM
sd4363's Avatar
sd4363
2011 Ford Explorer
I was changing my air filter and found oil residue on the filter and oil in the intake ducting. I took it in they say it's supposed to be there. I need some direction!!!!
Old Oct 31, 2014 | 08:36 AM
pawpaw's Avatar
pawpaw
IMO this isn't normal & shouldn't be there. Some paper air filters are now lightly oiled, but shouldn't have so much that it drains, or is pulled off with air flow, as that could foul/bake on the MAF sensors heated element, that's just a short distance down stream of the air filter & corrupt its PID output to the computer about true airflow into the engine & that could affect fuel trim, mpg & driveability problems, like engine ping, or bog down (from being slow to respond) from a lean air/fuel mixture when you go at throttle up.
EDIT: If it was an over oiled foam, or cotton gauze type air filter, they're known to bleed oil & foul the MAF sensor.
Is this puppy still under warranty???? If not, how many miles on it now, what brand, or type air filter was it & what service grade & viscosity engine oil are you using???? What is your drive cycle & driving conditions like???
Have you looked at, or changed the PCV valve & if so, is it OEM???
Some thoughts for consideration, with more details, the forum may be able to offer up more focused ideas.
Old Nov 4, 2014 | 12:33 PM
greenpus's Avatar
greenpus
"Ford advised: replacing the valve cover to incorporate the latest design of the vent tube which now has an internal baffle to prevent oil from migrating all the way up to the air intake tube and to the throttle body."
QwkTrip
Jun 24, 2007 05:51 PM
Impacttec1
1997 - 2003 F150
Jul 31, 2006 09:01 AM
truchafuego
Jan 10, 2006 10:23 AM
Drew2070
Aug 15, 2004 06:06 PM
firenut
May 7, 2001 11:57 AM
