6.7 Coolant Filter Questions
Old Oct 29, 2014 | 12:26 PM
Robby Nash's Avatar
Robby Nash
Anyone running a coolant filter on 2011+ 6.7s? I ask because I owned a 6.0 and still have the Sinister filer and trying to see if I could use it on my new 6.7. I'm sure it’s not as necessary as the 6.0 needing one but worth a try if it helps longevity of my new truck. Any Pics out there of anyone that has done this?
Old Oct 29, 2014 | 12:46 PM
Robby Nash's Avatar
Robby Nash
Here is a pic of the new 6.7
Old Oct 29, 2014 | 01:27 PM
djousma's Avatar
djousma
I used to run one on my 6.0, never put one on my 6.7. No doubt it would do some good, but you also do not hear about the plugged egr coolers like you did on the 6.0's either.
Old Oct 29, 2014 | 02:55 PM
Blapensee's Avatar
Blapensee
changed my radiator a month ago and found grit in the buckets of drained coolant. i decided put a coolant filter on with the new radiator heres a link to the installed pictures if your interested didn't cost a lot i recommend making the kit yourself like i did and save a few bucks
https://www.ford-trucks.com/forums/1...installed.html
Old Oct 29, 2014 | 07:07 PM
03 SVT VERT's Avatar
03 SVT VERT
The 6.7L has two totally seperate cooling loops. A high temp loop and a low temp loop. If you do put a filter system in, make sure it's a setup specifically designed with the 6.7L in mind. Here's an article about it:
http://www.dieselpowermag.com/tech/f...rd_67l_engine/
stufarmer
Dec 30, 2017 10:09 AM
ROBBINthaHOOD
Jul 21, 2013 08:36 PM
Dyllan78
May 4, 2010 07:36 PM
Maxium4x4
Nov 5, 2006 09:24 PM
