ignition switch
Old Oct 28, 2014 | 12:45 PM
abyars111's Avatar
abyars111
ignition switch
I ordered an ignition switch for my truck from Green Sales and they sent me the unit with blade terminals. This is on my 1970 Crew Cab. I removed my old switch and it has the round pin type terminals. I've heard some say the blade terminals are better. I don't mind swapping out the wiring for the blade type switch as it seems my 1970 should have this type. Is there a source for the correct female terminals and plug to fit the blade terminal switch?
Old Oct 28, 2014 | 01:01 PM
JEFFFAFA's Avatar
JEFFFAFA
This came up in another thread just yesterday. ND and I both remember Ford part number D1AZ11572C used to come with the pigtail you are asking about. They didn't service the pigtail separate. Just in this kit. Someone chimed in they heard Ford does still supply that part number but now it doesn't come with the pigtail. ND basically said Hogwash. So I looked at the one we have here in stock to prove he and I correct. It's no pigtail and pin style rather than the blade style it's supposed to be. I figured ours was boxed wrong. So I had a local Motorcraft Distributor deliver to me one of theirs. In their box was the same as ours. No pigtail and pin style. They are showing 24 of them in stock. If you want I can call them and have them look inside their boxes and find one that is correct (blade type and has a pigtail). PM me if you don't find an aftermarket pigtail.
Old Oct 28, 2014 | 01:02 PM
JEFFFAFA's Avatar
JEFFFAFA
Check this one.
<TABLE id=threadslist class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR><TD class=thead colSpan=2> </TD><TD class=thead width="100%">Rating Thread / Thread Starter </TD><TD class=thead width=150 noWrap align=middle>Last Post </TD><TD class=thead noWrap align=middle>Replies </TD><TD class=thead noWrap align=middle>Views </TD></TR></TBODY><!-- show threads --><TBODY id=threadbits_forum_39><TR><TD id=td_threadstatusicon_1342497 class=alt1> </TD><TD class=alt2> </TD><TD id=td_threadtitle_1342497 class=alt1 title="I have a 1968 F100 that a PO has replaced the ignition switch with a toggle and a starter button. I would like to change this back to a keyed..."> 1968 Ignition Switch
ovalholic
</TD></TR></TBODY></TABLE>
Old Oct 28, 2014 | 01:29 PM
abyars111's Avatar
abyars111
Thanks, I missed that post.
I called Sunbury Motors and they didn't have any pigtails in the box.
Old Oct 28, 2014 | 02:08 PM
JEFFFAFA's Avatar
JEFFFAFA
And I called that Motorcraft distributor (USD) that Bill mentioned in that other thread. 20 out of their 20 do NOT have it either. I know it used too. That's the only way Ford serviced that pigtail.
BTW, thanks for the REP. REP'ed ya back.
Old Oct 28, 2014 | 04:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different ignition switches were used in 1970. The serial number is the last 6 digits of the VIN / When you contacted Green, did they ask you for your VIN? Probably not.
1968/69 and 1970 F100/750 before serial number G90,001: D1AZ-11572-C .. Ignition Switch (Motorcraft SW-1054) / Available from Ford.
This switch is the "service part replacement" for the POS original C8AZ-11572-A switch that shorted out and caught fire!
Originally this switch came w/a pigtailed wire harness/plug, so the wires could be spliced to the dash harness.
Back then there were no mandatory US Gov't recalls. FoMoCo sent the dealers a "campaign letter" advising them of the problem and the fix. It was then up to the dealers to contact the customers.
Some dealers did, some did not. But some customers, when contacted...never responded to having their vehicles fixed under this recall warranty...so the POS original switch could still be present.
Since JEFFFAFA has this switch, ask him if it has blades or not, because I cannot remember.
1970 from serial number G90,001 & 1971/76 F100/750 : D0TZ-11572-A .. Ignition Switch-6 blade terminals (Motorcraft SW-944) / Available from Ford.
This switch was not problematic.
Old Nov 1, 2014 | 05:18 PM
abyars111's Avatar
abyars111
I found the plug I needed with the flat blade terminals I have a source. I got one from a buddy that sells used parts. He has several of the plugs with flat blades and the round pins. Let me know if you anyone else needs one and I'll forwaed his contact info.
Old Nov 5, 2014 | 01:08 PM
abyars111's Avatar
abyars111
Does anyone know where to find the OEM style terminals Ford used for the ignition switch connector? The junkyard blade type pigtail I have for my ignition switch has the resister wire going all the way to the terminal that plugs onto the ign. switch terminal. I want to remove the female terminal from the connector and install a new female terminal on a new 14 gauge wire so I can then connect that to the resistor wire in my truck.
Old Nov 6, 2014 | 11:14 AM
abyars111's Avatar
abyars111
Has anyone ever removed the blade type terminals from the connector on the rear of the ignition switch. I've tried with several thin blades and cannot move it. I'm I correct that I have to insert a thin blade into the front of the connector?
Old Nov 6, 2014 | 11:26 AM
abyars111's Avatar
abyars111
I got it. Just took more pressure.
Does anyone know of a supply for these?
Old Nov 6, 2014 | 11:34 AM
abyars111's Avatar
abyars111
I found them here:
Electrical Terminal 14-12 Gauge 1/4" Female
The have several wire sizes available.
Does anyone have any experience and/or tips on crimping these.
Old Nov 6, 2014 | 11:57 AM
abyars111's Avatar
abyars111
I found another supplier.
https://www.belmetric.com/electrical...cv53l1s6qemcf4
Old Nov 6, 2014 | 10:10 PM
orich's Avatar
orich
I order a couple of them but said 3-4 days before they would be in. So this was the only missing link to having it back up and running again.
I was with 1 block from PnP and went an bagged the HEI ign wire from a Chevy truck.
It's also Pink so removed the resistor wire from my ford ign switch plug snapped the chevy #10ga. wire and back up and running. I ended up leaving in there and just kept the extra clips I ordered for spares.
Orich
Old Nov 7, 2014 | 08:19 AM
abyars111's Avatar
abyars111
I forgot about the Chevy HEI wire having the same type of terminal. I ordered a handful of the locking terminals from Belmetric yesterday. They shipped them the same day. I'll post some pics when I switch it out.
_mtnbiker
Nov 26, 2018 10:36 AM
69rangerhiboy
Oct 26, 2017 10:04 AM
jrockdiddy
Apr 27, 2015 05:20 PM
TUNDERDIESEL
Large Truck
Sep 2, 2011 03:28 PM
medic85
Dec 23, 2007 08:02 PM
