2000 excursion swaping 03 power heated memory seat problems! How do I delete memory function?
Old Oct 28, 2014 | 10:32 AM
skibumsd's Avatar
skibumsd
I picked up a 2000 excursion with power drivers seat but both the front leather seats where in rough shape. I found 2 leather power heated front seats out of a 03 excursion so i purchased those to swap. The drivers seat is giving me some wiring issues. I went to the junk yard and got the wiring harness for the front seats out of a excursion. I tried just powering up the drivers seat from instructions on other posts here but no go, no power or heat. The drivers seat appears to have a memory function and I cant figure out how to by pass it. Has anyone done this or have any sugestions? Thanks Jayme
Old Oct 28, 2014 | 06:47 PM
Geeeyejo's Avatar
Geeeyejo
I believe you should be able to swap the seat track from the original seat to the new seats - then you should have no wiring issues. A little late perhaps but I picked up a seat bottom cover replacement from theseatshop.com - a few hours of pain in the *** work but looks like new now!
Old Oct 28, 2014 | 10:25 PM
skibumsd's Avatar
skibumsd
The biggest thing I was shooting for was the heated seats. Our winters are pretty chilly in SD. I came up with a idea after I took the seats out and looked at the bottoms. The passneger 03 heated seat only has 3 wires so I am going to remove all the extra modules in the drivers seat and wire it the exact same as the passenger with the seatbelt wire and I should be good to go.
Old Jan 19, 2015 | 12:28 AM
superdave02f552's Avatar
superdave02f552
Sooooo how did you end up here I have the same issue sort of I get the Orange light on the switch on but no heat in either seat I could see one being bad but not both any words of wisdom?
BLUEOX852
Apr 3, 2017 08:48 AM
k9dr
16
Nov 3, 2014 05:37 AM
Ckrau-18
Sep 19, 2014 02:36 PM
HowieE
Mar 1, 2013 09:19 PM
rowekmr
Mar 5, 2008 12:09 PM
