death wobble woes....
Old Oct 27, 2014 | 08:55 PM
Mihylo33's Avatar
Mihylo33
2005 PSD 290k Stock except for the EGR delete.
I've been having a vibration around 60 mph and while running at speed and left hand turns the front end would hop and shake something horrible. So I finally decided to do something about it. First I replaced the front Ujoints since they were beyond need of repair and I also replaced the front right (passenger) bearing and hub assembly since it was toast. Still had the vibration and the jump but not a big deal because I ordered my tie rod ends as well. I replaced them and still no change. I read some more, talked to some people and they all said to replace the tracking bar bushings which I did and now this thing is worst than ever. Tire pressure is good. I have never done an alignment on this truck but never had the need for one since the tires wore evenly and I get about 80k out of them. I'm about due for new sneakers, but want to get this sorted out. I'm not sure what to do next. Any ideas?
Thanks,
M33
Thanks in advance
Old Oct 27, 2014 | 10:21 PM
mustang_309's Avatar
mustang_309
Thanks,
M33
Thanks in advance
The hop sounds like its stuck in 4 wheel drive, remove the front drive shaft and see if the hop goes away. When you did the track bar bushing did you also do the track bar ball joint? And how do the ball joints look?
Old Oct 27, 2014 | 10:58 PM
twigsV10's Avatar
twigsV10
Has this been a problem that has persisted through multiple sets of tires? If it's been with the same tires I'd guess that the front right tire was out of balance, 60 mph is about where you will start feeling the wheel shake and usually only gets worse with time (the tire wears unevenly from bouncing). Try swapping the front tires to the back and see if it changes.
Old Oct 28, 2014 | 04:32 AM
Mihylo33's Avatar
Mihylo33
I had the front hub lock out and it was still there. I didn't think to check the ball joints but they look in good shape. I will have check them tonight.
I think there was a vibration before I put the current set of tires on but never a hop while steering left and hitting bumps. I will rotate front to back to see what happens... The track bar ball joint is new as well.
I did re-tighten the drivers side bushing on the track bar. It wasn't loose but I was able to crank it down tighter....
Thanks fellas
Old Oct 28, 2014 | 09:03 PM
Mihylo33's Avatar
Mihylo33
update:
Rotated the tires front to back. The bad shake at 60+ is gone. It still has a vibration and it still jumps when steering left and hitting a bump in the road at the same time, but only at speed. I was unable to reproduce a death wobble here on my local roads. I noticed some movement in the new upper bushing I installed on the track bar when turning left to right and vice-versa. There should be none, correct?
Also checked the ball joints. The drivers side is questionable.
Thanks.
Old Oct 29, 2014 | 12:44 AM
twigsV10's Avatar
twigsV10
The vibration is possibly the the tire that was in font still bouncing in the back. If swapping the front and rear tires made A difference it's very possible that that it damaged the front shock.
Old Oct 29, 2014 | 04:46 PM
HT32BSX115's Avatar
HT32BSX115
Thanks,
M33
Thanks in advance
Howdy,
With 290,000 miles, I would look closely at any tie-rod ends you DIDN'T replace, ball-joints and maybe the steering-box and pitman-arm.
Also, if it changed when you rotated the tires, look for out-of-round tires, lost wheel weights and under-inflation or a combination of all.......
If you're using 12.5 x 16.5 or larger tires, you may have the bead slipping on the rim making them go out of round.....
I had an 86 F-250 4x4 that had 12.50 x 16.5 tires on it and I never could keep them to stay in one place on the wheels.
Old Oct 29, 2014 | 05:04 PM
ul37's Avatar
ul37
Remove the steering damper. compress the piston if there is any free movement in the damper replace it. 8 outta 10 times that's whats causein it.
Old Oct 29, 2014 | 08:45 PM
Mihylo33's Avatar
Mihylo33
All my tie rod ends are new but the drag link by the pitman has some slop so that is getting replaced along with my ball joints, steering dampner and all 4 sneakers. I'll follow up with an alignment. Lets see what happens. Luckily I can do all this work myself except for the tires...
I have read that even tough I replaced the track bar bushing that the trackbar itself could go bad.
Old Nov 1, 2014 | 07:49 AM
Mihylo33's Avatar
Mihylo33
update:
Still haven't been able to reproduce the death wobble. Still have the hopping over big bumps at speed while steering left. I will replace the steering stabilizer and center link this weekend if I get the chance. I'm thinking of trying a different tire, maybe go back to the original Pirellis.
Old Nov 1, 2014 | 08:46 AM
KIDkiser's Avatar
KIDkiser
How old are your shocks?
Old Nov 2, 2014 | 12:52 AM
twigsV10's Avatar
twigsV10
That's a excellent question. Even if they aren't that old a out of balance tire can be the death of a shock absorber.
Old Nov 2, 2014 | 06:26 AM
Mihylo33's Avatar
Mihylo33
Shocks are pretty old...... I should order some new ones but want to get some of this stuff replaced and new tires thrown on. I'm going to go with the General Grabbers AT2 I think. I've used them before and got about 90k out of them.
Old Nov 2, 2014 | 07:35 AM
tonefordays's Avatar
tonefordays
Have you considered adding a dual stabilizer set up to the front end? With a stock set up, you shouldn't have to, but they do make a significant difference in the stability. They're easy to install, not that expensive, and it's nice knowing that when you hit a bump in the road, the tires stay glued to the road.
Old Nov 2, 2014 | 08:45 AM
Mihylo33's Avatar
Mihylo33
I just ordered the KYB heavy duty stabilizer from Rock auto and probably do the heavy duty shocks from them later. Thanks
RedTonka07
Oct 19, 2018 11:40 AM
chad41d
Mar 31, 2017 10:28 PM
mediaman67
Aerostar
16
Sep 1, 2009 11:48 AM
arkredneck
39
Oct 17, 2007 06:29 PM
wolfmanagh
Aug 31, 2006 09:16 PM
