p132b code
Old Oct 26, 2014 | 10:47 AM
ryan044x4's Avatar
ryan044x4
p132b code
Just joined today please bare with very new to this site and to the would of diesel trucks
Ok I just bought a ford f350 4x4 diesel truck with 115000 miles on it . 6.0 engine .. check engine like just came on .. with the code p132b I've read it can be a number of things .is this a bad thing?. the truck to me is 7 days old . Thanks for any help
Old Oct 26, 2014 | 11:40 AM
senix's Avatar
senix
Welcome to FTE. I moved your post to the 6.0 specific section for the experts with this motor to chime in.
Old Oct 26, 2014 | 12:54 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Welcome to FTE.
First question? Can you get something to read PIDs. Like MAP, BAR and the likes? Something to monitor your motor. You will need more info for this code.
Second question, is this an early build 04 or late build? Check passenger valve cover for the ICP sensor, which if there, will be kind of under the alternator area of the valve cover, this will tell you it's a late build. No sensor there means early build.
Try cleaning the following sensors. MAF sensor (Use MAF sensor cleaner only), MAP sensor/hose, IAT2 sensor and the EBP sensor. Also check for exhaust leaks. Check the fire wall for soot. (Can you smell exhaust in the cab?)
https://www.ford-trucks.com/forums/1...l#post14080699
Others will chime in I'm sure. Lots of info on the P132b code.
Old Oct 26, 2014 | 12:56 PM
amdriven2liv
After these checks and cleanings, you might need to clean the turbo. VGT vanes might be sticking.
stinson 108-1
2009 - 2014 F150
May 3, 2019 06:10 AM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
PERFICUT L&L
Dec 19, 2010 06:36 PM
ballbandit
Escape & Escape Hybrid
Jul 11, 2009 10:32 PM
