1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
water/ electric damage.....help!
Old 10-25-2014, 06:40 PM
johnpaulmelone's Avatar
johnpaulmelone
johnpaulmelone is offline
I have a 2001 f250 5.4 triton. My cb antenna hole leaked water in cab, soaked my fuse block. Horn goes on and off, radio turns on without key in ignition, truck only starts when key is on and I bridge solenoid, and number 4 coil is not firering. I have let truck dry out, fixed the leak. Everything is bad to normal except starting issue and coil issue. Any ideas?
Old 10-25-2014, 07:45 PM
bigcountry1009's Avatar
bigcountry1009
bigcountry1009 is offline
Are the coil and solenoid themselves working? Is there any sort of fuse or link burned out?
Old 10-25-2014, 07:56 PM
johnpaulmelone
Yes, three new solenoids, and two brand new coil. Both are new.
Old 10-25-2014, 07:57 PM
johnpaulmelone
And checked every fuse....
Old 10-26-2014, 08:04 AM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
You might try some contact cleaner on the fuse block terminals. Pull each fuse one at a time to clean the terminals.
Also did you pull every fuse and relay to check the terminals for oxides?
Its quite possible that you have some water logged relays that may need to be replaced.
Old 10-26-2014, 08:46 AM
Sous's Avatar
Sous
Sous is offline
Received 4,572 Likes on 2,900 Posts
As noted above, I would remove each fuse and use some very light emery cloth on the fuse pins itself if required and electrical contact cleaner spray with a dental pick if needed in the fuse block. Of course, remove power by disconnecting the battery before doing anything electrical in nature
Old 10-26-2014, 02:58 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Might be corrosion inside the fusebox.
Deebo
1997 - 2003 F150
10-29-2023 05:31 PM
Troy77+79
1997-2006 Expedition & Navigator
03-09-2011 10:24 PM
Brian Hebert
13
09-05-2009 10:21 AM
peanutzfarmer
Modular V8 (4.6L, 5.4L)
10-18-2008 09:41 AM
dennydamnit
1983 - 2012 Ranger & B-Series
05-12-2004 03:49 PM
Quick Reply: water/ electric damage.....help!
