Ignition coil fuse?
Old Mar 9, 2011 | 06:56 PM
Troy77+79's Avatar
Troy77+79
Ignition coil fuse?
I've got a 1999 Ford Expedition 5.4 V8. Can someone tell me which fuse supplies power to the ignition coils? I'd like to be able to turn the engine over with the starter without it actually starting.
Old Mar 9, 2011 | 10:10 PM
projectSHO89's Avatar
projectSHO89
See owner's manual.
Old Mar 9, 2011 | 10:24 PM
alloro's Avatar
alloro
You're better off pulling the fuel pump fuse. I believe it's #10 in the fuse box under the hood. The ignition one is #113. The reason I wouldn't pull the ignition one is because you run the risk of throwing off other electronics within the vehicle.
Stuck in germany
Jun 19, 2022 11:43 PM
westend
Feb 14, 2018 12:32 PM
mcmain
Aftermarket Products
Nov 7, 2016 03:33 PM
jay hay
Sep 28, 2016 06:00 PM
jeffie_3
May 14, 2016 10:19 AM
