NO START, please help
Old Oct 25, 2014 | 09:00 PM
Jmoen7's Avatar
Jmoen7
Originally Posted by yasky69
ECT was at 186 when I shut it down
FYI- I watched the volts drop to 10.8 when trying to start
Yeah that's warm enough then. Was that 10.8 while cranking, or 10.8 with glow plugs on? What was your batteries volts before any of that?
Old Oct 25, 2014 | 09:52 PM
firedaniel's Avatar
firedaniel
If your IPR is jumping up to 84 IPR most likely needs STC fitting done and dummy plugs if it wont start when warm. Common problem on that truck.
DW
Old Oct 26, 2014 | 07:12 AM
bismic's Avatar
bismic
post deleted .
Old Oct 26, 2014 | 07:25 AM
bismic's Avatar
bismic
10.8 V is definitely too low - even when cranking w/ the glow plugs on.
Old Oct 26, 2014 | 10:18 AM
yasky69's Avatar
yasky69
I'll be getting the batteries load tested this morning. My gut is telling me those or the Alt as stated before.
IPR is at 14.8 KOEO
Now jumping right to 84 upon cranking when hot
Maybe it is the STC
I also think its in my best interest to get some mods done asap
Coolant Filter
STC/dummy plugs
Blue spring
Old Oct 26, 2014 | 01:52 PM
yasky69's Avatar
yasky69
Here's where I'm at
When running this morning volts was at 13.7- tells me the ALT is ok
Load tested both batteries.
They are Ford Motorcraft dated 9/13 and both tested better than the label on battery
Looks like its gonna be a STC/dummy plug job
Since they are gonna have to fix that, I think I'll talk to them about getting the EGR delete done at the same time. I'd rather only have the top end pulled off once if I can
Old Oct 26, 2014 | 10:27 PM
firedaniel's Avatar
firedaniel
Have you checked the temp spread for the oil cooler? Thats a common issue and its right by the STC and would be easy to do. Just a thought
DW
Old Oct 27, 2014 | 10:43 AM
yasky69's Avatar
yasky69
DW
Yes, the temp spread is around 8
Dropped it off to them today. They are gonna have to send it out to there diesel guy that works on all there 6.0's
I'll be in close contact with there mechanic. If they are going to be into it that far I want the EGR delete done as well.
Old Oct 29, 2014 | 10:09 AM
yasky69's Avatar
yasky69
Heard back from the dealer today. There diesel mechanic that is 45 min's north said the problem is the dummy plugs on the oil rail and claims it to be a 5 hour job.
I was kinda hoping it would be the STC, that way I could get the EGR delete at the same time.
Also got my coolant filter kit today VIA UPS, so that's gonna be my weekend project
Old Oct 30, 2014 | 06:33 AM
yasky69's Avatar
yasky69
Got that "new truck" feeling back...
f250d4x4
1997 - 2003 F150
18
Jul 9, 2015 12:02 PM
mxer0022
May 20, 2013 10:53 PM
d450
Apr 24, 2008 08:26 AM
