Sponsored by: Real Truck
leveling kit
Old Oct 25, 2014 | 03:22 PM
brangus82's Avatar
brangus82
leveling kit
Anyone put a leveling kit on a f350 2wd crewcab pickup? I have a 2015 with the 6.2. Is it a spacer? Easy to install? Cost? Thanks
Old Oct 25, 2014 | 05:34 PM
V10man's Avatar
V10man
Are you are talking about the spacer that goes under the coil spring? My son and I put one on his 96 F250 and it was pretty simple. It really did improve the stance of his truck. I have looked at this one for my 2002. http://www.ebay.com/itm/Front-Leveling-Kit-2-Lift-for-99-08-Ford-F250-F350-2WD-Silver-Spacers/380972451938?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3D0d02a9f78b8647f181484a3439ab2f15%26pid%3D100005%26prg%3D20131003132420%26rk%3D1%26rkt%3D6%26sd%3D121352518438&rt=nc
I have read here that you may need to grind the parts of the spindle where it attaches to the I beam. When you get it aligned the spindle gets moved closer to the I beam with the new ball joint and alignment shim.
Old Oct 28, 2014 | 11:29 AM
ChadJThayer's Avatar
ChadJThayer
Looking at doing this, could you also use the kit that opposes the kit at the same time? Example, lower leveling kit for 2 inches on bottom of the spring assembly and two inch leveling kit for the top of the strut? Need 4 inch but not 6 inches and am on a budget as its my family vehicle and daily driver.
Old Oct 28, 2014 | 05:35 PM
V10man's Avatar
V10man
There isn't enough alignment adjustment for that much of a lift. I wouldn't think double spacers would be safe either.
Old Oct 28, 2014 | 06:38 PM
2ndStroke's Avatar
2ndStroke
I did the bottom spacers on mine, 4x4 though, pretty easy, did it in my driveway.
Old Oct 31, 2014 | 08:19 AM
ChadJThayer
That's a good point. I have been looking for a 3 inch spacer. Is the alignment adjustment the reason that Im only finding 2inch spacers? Id love to have as much as I could get but obviously the price jumps quickly after spacers. Thanks for you insight.
My buddy at the tire shop said I should be able to fit a 285/75/16 with the 2 inch level. Ive found a 3in body lift but it seems odd to spend $300+ for a body lift.
Bvill01
Oct 13, 2012 07:30 PM
viper69
2004 - 2008 F150
Feb 5, 2007 07:09 PM
lombardo96
Feb 16, 2006 08:39 PM
bones68
Jan 3, 2006 08:53 PM
mhamFORD_FAN
2004 - 2008 F150
16
Sep 26, 2004 01:13 PM
