Leaky Radiator Question...
Old Oct 24, 2014 | 06:47 PM
WalterRoad's Avatar
WalterRoad
I have a radiator that leaks- under about 5lbs of pressure it hisses out in a few tiny spots in the radiator (I put a pressure gauge/pump tester on it) but while driving doesnt take more than a gallon an hour of driving (I have to keep topping it off).
Under no pressure, like while standing still, it stays full for weeks. Is there a way (like leaving the cap off) that I could go 2-4 hours of highway driving where it runs cool with no pressure on the cooling system? (at the other end of this trip is my trusted garage). If I stop every so often and make sure I'm topped off, is there a way to eliminate pressure on the cooling system so I can safely make such a trip? Would leaving the radiator cap off do it?
Sorry if this is a silly question, but hearing from those who know would put my mind at ease... thanks!
Old Oct 24, 2014 | 07:09 PM
Harte3's Avatar
Harte3
I would try some AlumAseal Stop Leak Powder to at least get you where you are going.
Old Oct 24, 2014 | 08:48 PM
WalterRoad's Avatar
WalterRoad
Yes, but does leaving the radiator cap off allow cooling for the engine without buildup of pressure in the radiator?
Old Oct 25, 2014 | 10:28 AM
Harte3's Avatar
Harte3
Yes...but without pressure the temps don't stabilize as they should and there will probably be some loss of coolant as it expands and then pukes out the filler neck...and then the radiator will be low on coolant...which is what you are trying to avoid.
Try the Aluma powder...I have yet to have it fail to stop a leak when used as directed.
Old Oct 25, 2014 | 01:16 PM
JimsRebel's Avatar
JimsRebel
Leaving the rad cap off is a bad idea, it will just puke out all the water. I did this by mistake so I know.
ALUMASEAL Radiator Sealer Powder, .70 oz - G2110647 at Zoro
alumaseal is worth a try.
Driving for 1-2 hours than let it cool down and refill is a workable plan. This is the safest answer.
Idea answer would be a 2 PSI cap. or maybe removing part of the sealing rubber on the cap, but then you would have to buy a new cap.
The older style rad caps had a lever on top that released pressure by pulling up the lever. So if you left the lever up it wouldn't build up pressure.
Good luck and take the safest approach to getting the truck to the garage to get it fixed.
Jim
Old Oct 25, 2014 | 01:21 PM
JimsRebel's Avatar
JimsRebel
http://ecx.images-amazon.com/images/I/4159N4MW35L.jpg
Here is a picture of the rad cap with the pressure release lever.
This will only work if you can create a small air leak by cracking the release lever a little.
npccpartsman
Aug 17, 2011 11:29 AM
AJHEATING
Aug 24, 2010 10:20 PM
77ford guy
May 13, 2006 05:44 PM
prginocx
May 14, 2004 01:12 PM
emba129
Oct 4, 2002 01:45 PM
