Proper radiator cap pressure
Old May 12, 2004 | 04:57 PM
prginocx's Avatar
prginocx
I think the one I have now is 13psi. Is this correct ?
292 V8, 4spd manual, 4X4. 1964 F100.
Old May 12, 2004 | 07:02 PM
cdherman's Avatar
cdherman
If it is an original radiator, then NO. The older style radiators, with large volume reservoirs at the top and bottom, are simply not strong enough to handle the higher pressure. From basic physics -- the wall stress of a chamber goes up as a square of the diameter of the chamber -- this means that given equal pressures, a large volume reservoir on the radiator is much more likely to blow up like a shook-up can of Coke, as compared to a small volume reservoir.
Now, I have heard that replacement radiators these days are made enough stronger that they will handle the 13lb caps. But, the cooling gains are marginal, and if you are not getting things cool with a 7 lb cap, then you are probably not going to solve things with a 13 either. And the resultant leak or ballooned radiator you may possibly get is not going to cool very good either.
Old May 12, 2004 | 07:47 PM
prginocx's Avatar
prginocx
More info on Radiator
Well I have determined the radiator was replaced in the late 70's. So this is probably the proper cap for it. I still don't understand why I am constantly losing coolant.
Old May 12, 2004 | 07:59 PM
barry's Avatar
barry
Have the cap checked to see if it's holding pressure at 13lbs. It may be failing and blowing cool.ant out the overflow. Any radiator shop or a good mechanic will have a device to test it.
Barry
Old May 12, 2004 | 08:28 PM
KenB's Avatar
KenB
Where are you losing coolant from? or can you tell?
Old May 14, 2004 | 01:12 PM
prginocx's Avatar
prginocx
Can't see the source of coolant loss
Yesterday I was working on #&%* Voltage Regulator so I did actually watch it work with the new radiator cap (13Lbs). Engine gets hot, reservoir level goes up, Engine cools down, reservoir level goes down. I didn't see any coolant loss at all. Maybe the new cap fixed the problem. I'll wait and see, especially on a hot day...
Slapshottr
Dec 21, 2016 05:52 AM
waterfowl14
1997 - 2003 F150
Apr 4, 2012 08:05 PM
fishpimp
Sep 16, 2009 06:13 PM
joeskeeter
Feb 21, 2008 10:23 AM
mikedeason
Apr 2, 2007 10:38 AM
