c6 problems
Old Oct 23, 2014 | 03:21 PM
69issofine's Avatar
69issofine
c6 problems
i have a c6 out of a 1970 f-250 the internal linkage was messed up the shift rod inside was to far forward and would not move. so i took the extension housing off and the valve body off and the governor tubes off i got the linkage working but i can't get the tubes in all the way and if they don't go in all the way the extension hosing won't go on. is there a way to get those tubes in all the way or should i buy new ones and where would i buy them?
Old Oct 24, 2014 | 08:33 PM
BobbyFord's Avatar
BobbyFord
In the governor housing or in the trans. If the tubes haven't been bent, a little wiggling is usually all it takes.
Old Oct 25, 2014 | 09:17 AM
tasboj's Avatar
tasboj
Yeap what he said a little wiggling.
Old Nov 10, 2014 | 12:20 PM
69issofine's Avatar
69issofine
c6 problems
they may have been bent a tiny bit that whole park assembly was disassembled i got most back together except the governor tubes i will see if i can persuade them gently then find a new gasket fir the extension housing.
71BlueBoy
Nov 27, 2012 09:16 AM
MAULMAUL
23
Aug 30, 2012 08:44 AM
mrfox_88
Aug 18, 2009 01:54 PM
Rcmgiasson
Jan 3, 2005 12:17 AM
cj7taz
Jul 4, 2003 08:49 PM
