c6 transmission shifting question
Old Jul 4, 2003 | 08:30 PM
cj7taz's Avatar
cj7taz
i have an 88 f250 with a 351w with a c6. trans was shot so i found a used c6 from an 87 bronco. my problem is under hard acceleration it won't go into high gear. now with the kick down cable disconnected the trans shift's just fine. i have replaced the modulator valve.
the kick down cable has been replaced also. the engine is new.
Old Jul 4, 2003 | 08:47 PM
cartwright's Avatar
cartwright
The kickdown lever on the trans might be stuck. I had that problem with a brand new TCI. I got under there and wiggled it till it loosened up, then hooked the kickdown rod back up and its worked right ever since. If that doesnt work, the governer counter weight might be gummed up and stuck, in that case you have to remove the tailshaft housing, take the governer off, and clean it out with solvent. Its an easy job to do, just make sure the oil passages line up right when you reinstall it.
Old Jul 4, 2003 | 08:49 PM
cj7taz's Avatar
cj7taz
i just dropped the valve body and installed a new kick down rod.
cherrybomb37
Jun 9, 2014 02:03 PM
chamblizi
Aug 17, 2012 08:38 AM
smsperformance
Sep 6, 2010 09:56 PM
cornbinder
May 24, 2010 10:56 PM
jav409
Apr 26, 2008 07:59 PM
