? 1973 F600 Vin decoding
Old Oct 22, 2014 | 10:55 AM
Ed Winegarner's Avatar
Ed Winegarner
Would anyone be able to help me with this Vin# F60DV060041 I am trying to determine what size the engine is? Thanks Ed
Old Oct 22, 2014 | 02:14 PM
351Cleveland C4's Avatar
351Cleveland C4
You'd have better luck in the "large truck" forum. In the super duty group farther up the page.
Old Oct 22, 2014 | 05:44 PM
Ed Winegarner
oki doke thank you
Old Oct 23, 2014 | 06:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F60DV0?60041
Welcome to FTE
This is the 1967/72 forum, please post further questions in the Large Truck forum.
6th digit of the VIN is either the letter O or Q .. it's not a zero.
F60 = F600 (gas).
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
Q60,041 = 1973.
O60,041 = 1977.
Old Oct 23, 2014 | 07:39 AM
Ed Winegarner
Welcome to FTE
F60 = F600 (gas).
Q60,041 = 1973.
O60,041 = 1977.
Thank you that was what I was trying to figure out because the guy that sold it said it was a 391 & it's a 1973 Thanks again
Old Oct 23, 2014 | 06:46 PM
JEFFFAFA's Avatar
JEFFFAFA
Thank you that was what I was trying to figure out because the guy that sole it said it was a 391 & it's a 1973 Thanks again
It could be a 391 now. It was Originally built with a 330 HD. Check the stroke of the engine through a spark plug whole. BTW, 330 was 2V as noted above. 391's were 4V governed. But intakes can be swapped.
Old Oct 23, 2014 | 07:16 PM
Ed Winegarner
Okay I'm seeing the 2 V & 4 V what is the v for venturi?? This one has a 4 brl carb on it "Edlebrock" also I have never measured stroke through the spark plug hole. How would I go about that one? Screw driver and measure the distance up & down or ? I did find something that said put # 1 on tdc stroke and a piece of wire to mark both the # 1 & 4 cyls with. Is that correct & if so what would be the 391 something around 3.8" or ?
Thanks again Ed
Old Oct 23, 2014 | 07:45 PM
JEFFFAFA's Avatar
JEFFFAFA
Okay I'm seeing the 2 V & 4 V what is the v for?? This one has a 4 brl carb on it "Edlebrock" also I have never measured stroke through the spark plug hole. How would I go about that one? Screw driver and measure the distance up & down or ?
Thanks again Ed
"V" stands for venturi. That's how Ford list 2BBl,4BBL,etc. Yes,only most use a wooden dowel. Easier on the top of the piston and also easier to mark. Use the lip of the valve cover as a reference point.
Old Oct 23, 2014 | 07:50 PM
Ed Winegarner
391 around 3.8" or ?
Old Oct 23, 2014 | 07:51 PM
Ed Winegarner
Think I was editing my reply at the same time you was replying
Old Oct 24, 2014 | 05:15 PM
Ed Winegarner
We got # 1 on TDC made sure mark was on 0 and pulled # 4 spark plug. Marked both 1 & 4 and the dif we got was right at 4" does that make it a 391 or bigger?? I'm not sure but after cleaning it up would say it's Jasper rebuild.
Old Oct 24, 2014 | 05:56 PM
JEFFFAFA's Avatar
JEFFFAFA
391 has a stroke of 3.97".
Old Oct 24, 2014 | 08:21 PM
Ed Winegarner
THANK YOU VERY MUCH YOU HAVE BEEN A GREAT HELP!!! #91 is what we have here Thank you again for the help
Old Apr 15, 2015 | 01:37 AM
Bobdavis711's Avatar
Bobdavis711
Thank you guys!! I've been searching for hours trying to figure out what my engine is :F60DCE... Couldn't find anything that referenced the "D" until now!! Thank you!
Travis Gunter
May 17, 2019 01:03 AM
racerc2000
Large Truck
Jan 19, 2013 07:28 AM
pinn600
Large Truck
May 11, 2011 08:56 AM
dmanlyr
Large Truck
Sep 6, 2010 11:22 AM
mikem55
Jun 9, 2008 11:55 AM
