Sponsored by: Auxito
surging
Old Oct 21, 2014 | 08:19 PM
punisher321's Avatar
punisher321
surging
I have a 2001 F150 4X4 super crew 4.6L. I have recently been experiencing a surge in acceleration when I let off the gas. Also at times when I am at a complete stop and go to take off the engine will rev and not go anywhere then all of the sudden it like kicks into gear and chirps the tires. Why would this be happening?
Old Oct 21, 2014 | 08:36 PM
enriched&beyound's Avatar
enriched&beyound
Have you checked the throttle cable...make sure it isn't hanging up, or fryed cable.
Have you check for vacuum leaks? are your brakes kinda spongy?
Also you IAC (Idle Air Control) could be malfunctioning
Old Oct 21, 2014 | 08:41 PM
punisher321
surging
The brakes are not spongy, and There isn't a vacuum leak. I will check the throttle cable and then the IAC. Thank you enriched&beyond.
Old Oct 22, 2014 | 12:05 AM
Bluegrass 7's Avatar
Bluegrass 7
None of the above!
If the motor is revving in gear and your not moving forward, I believe there may be a transmission issue, not?
Good luck.
Old Oct 22, 2014 | 05:01 AM
enriched&beyound
Originally Posted by Bluegrass 7
None of the above!
Good luck.
^^I gotta agree ^^ just weeding out the simpler things 1st.
would this be more symptomatic of low transmission fluid? or torque converter issue ? or valve control?? or combination of previously mentioned?
PauL3861
Feb 2, 2015 10:15 AM
sibernut
Dec 20, 2011 06:10 PM
stumprider69
1997 - 2003 F150
Mar 10, 2011 05:45 AM
miafcowboy
Oct 14, 2010 08:10 PM
bsw9323
Mar 21, 2006 08:23 PM
