Gotta (high) idle problem
Old Dec 16, 2011 | 05:47 PM
sibernut's Avatar
sibernut
94 F150/302FI 2wd, A/C. engine idles high intermittently, anywhere from 1000 to 2000 while driving, almost like on "cruise". Feels like stuck throttle, real fun in traffic. Replaced TPS & throttle cable. Opened up intake, cleaned bores and throttle plates. Disconnected cruise cable. When I'm driving & it does it, if I put it in N while still moving it stays sped up for a second then drops to normal idle (750-800RPM).
Won't do it sitting still. Does it have a VSS somewhere that's FUBAR?
Any help appreciated!!
Old Dec 17, 2011 | 06:07 AM
Freightrain's Avatar
Freightrain
Idle air motor sticking? They get gummed up. Pull it off, clean it up with brake clean and see what it does.
They usually fail and make it not idle, but who knows?
Old Dec 17, 2011 | 07:48 AM
Tote-M-Pole's Avatar
Tote-M-Pole
Siber,
It does sound like the IAC. With that said have you checked for codes? Couple of thoughts
Unhook the throttle cable and manually actuate the throttle, it should feel smooth. Now do the same for the cable, it should also feel smooth.
Just my 2 cents
Old Dec 17, 2011 | 08:40 AM
fonefiddy's Avatar
fonefiddy
It sounds like a vacuum leak.
Old Dec 17, 2011 | 08:49 AM
sibernut's Avatar
sibernut
High idle
Tks, guys for the fast response! Yes, I have manipulated the butterflies with the cable off, even added a second spring temporarily to the linkage before the new cable. No different.
What is "IAC" ? I'll check out the vac leak thing ASAP. BTW, I have the A/C unplugged, so the compressor won't kick in & run it up. I am at the point that I'm ready to stand in front with M/W on the brake in D just to see what I can find. (I have no big life ins policy, no motive.......)
Old Dec 17, 2011 | 09:38 AM
ryan f150 4x4's Avatar
ryan f150 4x4
the iac is in the side or top of the throttal body its easy to test start the truck and unplug it it the tuck quites the iac is work if it says running it needs cleaning or replaced
Old Dec 17, 2011 | 11:28 AM
sibernut's Avatar
sibernut
IAC
I think what you are calling the IAC I would call the "mass air sensor", right ? I'll try it today, w the vac leak theory. TKS!
Old Dec 17, 2011 | 11:59 AM
ryan f150 4x4
the mass air is the the air intake tube not on the throttal body
Old Dec 17, 2011 | 02:05 PM
sibernut's Avatar
sibernut
MAF
OK, unplugged it, RPM dropped a hundred but didn't quit. Is there a proceedure for cleaning other than a blow out? New looks like $76, rather try a cleaning 1st.
Old Dec 17, 2011 | 08:02 PM
Freightrain
Unbolt it from intake, get yourself a can of brake clean(not carb cleaner) and spray it liberally in the two holes. Using a small scewdriver you should be able to move the rod back and forth. Look inside and you'll see the "valve" seat area. Make sure it's not carboned up. You can remove the soleniod portion and work on the valve itself.
How it works: it's a controlled vacuum leak as it allows more air pasted the throttle blades. If it sticks open/closed or gummy it will make it idle fast or slow depending on condition.
Usually cleaning them up will make a drastic change in idle quality.
Old Dec 20, 2011 | 06:10 PM
sibernut's Avatar
sibernut
Cleaned MAF sensor, replaced IAC. Still doing it, but better. Only idles up at 1500 now in gear, stopped. Keep the ideas coming, I appreciate the help!
johnfl
General Automotive Discussion
Nov 5, 2023 09:39 PM
imsorope
Apr 23, 2014 10:22 PM
mechelement
Sep 17, 2013 11:13 PM
ForsytheM13
Sep 12, 2010 04:07 PM
appliedcryogenics
1978 - 1996 Big Bronco
Feb 22, 2004 08:40 AM
