Sponsored by: Real Truck
Anti freeze?
Old Oct 21, 2014 | 12:40 PM
woody367's Avatar
woody367
Anti freeze?
Have a 04 F250 eith the 5.4, I am going to change the anti freeze. Do I need to use the Ford brand like I have been told or can I use like Prestone?
Old Oct 21, 2014 | 08:51 PM
Bently_Coop's Avatar
Bently_Coop
Here is a great how to on coolant flushing a Triton 5.4 V8. Definately use a 50/50 sollution with distilled water.
2004 F250 5.4L Coolant Flush
Will you be changin the thermostat at the same time?
Old Oct 21, 2014 | 09:01 PM
superrangerman2002's Avatar
superrangerman2002
Not necessary to use the ford product if you are flushing it out.
Old Oct 21, 2014 | 10:51 PM
dkf's Avatar
dkf
Either use the Motorcraft Gold coolant or Zerex G-05. Prestone is not exactly cheap. If you are thinking of going to a green prestone it is step back from either the MC Gold or Zerex.(much longer service life without th esilicate dropout)
Old Oct 22, 2014 | 03:03 AM
Yahiko's Avatar
Yahiko
Originally Posted by dkf
Either use the Motorcraft Gold coolant or Zerex G-05. Prestone is not exactly cheap. If you are thinking of going to a green prestone it is step back from either the MC Gold or Zerex.(much longer service life without the silicate dropout)
Where have I hear that before from.
Can you use the same ELC that we do in the diesels?
I put the red Shell Rotella in after getting the gold out.
Sean
Old Oct 22, 2014 | 11:05 AM
dkf's Avatar
dkf
Sean
I don't have experience with it so I am not up on the differences. If it is an acceptable replacement for the MC Gold in the 6.0l (which can be hard on coolant) I would say it should work fine in a modular.
Projectlittleredf250
Nov 14, 2017 04:30 PM
the almighty schmuck
Jul 20, 2011 05:05 PM
johnnkara
Nov 2, 2008 09:17 PM
wagntwister
Oct 8, 2008 05:42 PM
MeanGene1
2004 - 2008 F150
Nov 11, 2007 11:35 AM
