Sponsored by: Real Truck
Front end brake chatter
Old Oct 20, 2014 | 01:36 PM
Kaos8Delta's Avatar
Kaos8Delta
I have been having some brake chatter for awhile now. I have changed pads, changed rotors, rebuilt both front calipers, flushed all my brake fluid, and made sure my slide pins were good and free. I have noticed some weird wear on the new front rotors and was wondering if it was normal or not. I have no idea what else to do, any suggestions?
On a different note, I am having to replace my parking brake pads. When I had the axle out I looked in and saw a bunch of gunk. I was just looking on suggestions as to what I should do/should I be worried about this. Thanks
Old Oct 20, 2014 | 02:09 PM
senix's Avatar
senix
I would need pics of the rotors from a different angle and the old pads/new pads.
Something sure is wrong here.
It may just be the pads with incorrect compounds.
Old Oct 20, 2014 | 02:23 PM
Kaos8Delta's Avatar
Kaos8Delta
The old pads are gone. What other angles would you need?
Old Oct 20, 2014 | 05:02 PM
senix's Avatar
senix
Another view of the rotors and the calipers.
Old Oct 20, 2014 | 08:18 PM
Kaos8Delta's Avatar
Kaos8Delta
Just got done with the parking brake replacement, so I think I'm done for the night. I will post some more pics of the front rotors tomorrow, anything specific/angle that will help you diagnose it?
Old Oct 21, 2014 | 08:49 PM
Kaos8Delta's Avatar
Kaos8Delta
This tire on this side also started to feather and cup (I think thats the term), so I replaced the shocks, but the other tire did not do this. Not sure if relevant or not...
Old Oct 21, 2014 | 08:56 PM
senix's Avatar
senix
Have you checked your wheel bearings?
Put the tire on. Then see if you have some movement in the hubs.
That is about the only thing I can come up with.
A little strange wear on the rotors but the thickness is uniform.
Old Oct 21, 2014 | 08:58 PM
Kaos8Delta's Avatar
Kaos8Delta
I have replaced both hubs up front.
Old Oct 21, 2014 | 09:01 PM
senix's Avatar
senix
How many miles on the hubs and did you recheck the torgue?
Old Oct 21, 2014 | 09:14 PM
Kaos8Delta's Avatar
Kaos8Delta
Maybe a few thousand miles on them, and I guess you mean the mounting bolts on the hubs? Yes, everything was torqued to spec.
Old Oct 22, 2014 | 04:53 AM
senix's Avatar
senix
have you tried to rotate the tires and see what you get?
Old Oct 22, 2014 | 06:37 AM
meborder's Avatar
meborder
what year of truck are you working on?
Old Oct 22, 2014 | 04:32 PM
Kaos8Delta's Avatar
Kaos8Delta
It's a 2000. I'm gonna be getting some new tires pretty soon hopefully, so I think I'll just wait on the rotating. Would a balance or alignment issue cause this?
schlepprock250
27
Dec 1, 2021 08:57 PM
PlatinumPSD
Nov 2, 2007 04:10 PM
crosbo
Sep 28, 2007 12:11 PM
98SurplusExpy
2004 - 2008 F150
15
Nov 12, 2006 01:54 PM
zippinz
Aftermarket Products
Aug 5, 2002 08:56 AM
