help with c6 trans
Old Oct 17, 2014 | 09:09 PM
truckboss's Avatar
truckboss
help with c6 trans
hello, just joined.
I need some help with a c6 trans, my truck is an 86 f150 302 efi, its a c6 used trans, I've had the pan off to check filter, hardly anything in pan, fluid clean not burnt, refilled with old fluid and topped with new to fill.I have it on jack stands, tires off.
the trans acts like it low on fluid, I hooked a gauge to it and the needle goes
0--50--0--50--0--50--0 at idle in all gears and drums spin stop spin stop.
if I rev it to 1500-2000 the needle fluctuates like crazy between 50 and 90 in park and forward gears and 50 to 150-160 in reverse. the fluctuation is steady like a burnt valve would show on vacuum gauge, like jump jump jump, fast.
it shifts thru the gears when rev'd, I added more fluid to see if it helped/wrong dipstick, same results, any help would be appreciated
ps: tried vacuum hooked/unhooked, same
Old Oct 18, 2014 | 12:03 AM
stuart1's Avatar
stuart1
Were you able to wiggle the convertor before bolting it to the flex plate?
Are both pilots on the convertor the same size?
How much fluid was used?
Old Oct 18, 2014 | 08:43 PM
truckboss's Avatar
truckboss
c6
thanks for the reply. yea the converter was normal, didn't pay attention to much more and took 3 qts to fill.
started it today, pressure came right up to 55 held steady for a minute then dropped.
Old Oct 18, 2014 | 08:54 PM
stuart1's Avatar
stuart1
A C6 transmission takes close to 12 quarts of fluid.
You are a tad shy.
Old Oct 18, 2014 | 10:22 PM
truckboss's Avatar
truckboss
c6
when I drained the pan to check filter I dumped that used fluid back in, don't like putting all new fluid in used tranny plus the 3 qts I mentioned, converter was full when put in trans.
so whatever I drained from tranny, 6-8 qts? didn't measure plus the 3 I said to top off
its maybe 1/8th" below full mark on stick, I added more to see if it was wrong dipstick maybe, didn't help, sucked it back out
Davon3598
Oct 29, 2018 10:49 AM
swimnshoot
Jul 18, 2013 05:51 PM
PRIMERED79 SHORT BED
Jun 27, 2013 12:37 PM
ford390gashog
Jan 5, 2004 12:28 AM
