4.9L Lifting Lug
Old Oct 16, 2014 | 03:14 PM
KsCop's Avatar
KsCop
4.9L Lifting Lug
Saw a lifting lug on Ebay.
The description said it attached to the cylinder head and was used to lift the engine
Anyone ever seen or used such a thing?
I thought it might just be for lifting the head off, but they said it was for the engine.
I've heard of 4.9's with lifting lugs attached so..
Old Oct 16, 2014 | 07:53 PM
Franklin2's Avatar
Franklin2
Most engines are equipped with them from the factory. They just leave them on there. Some are taken off after the engine is installed, since they get in the way of something, and you can buy them to pull the engine. Most people don't use them, putting the chain through a longer 3/8 bolt somewhere in two places usually is enough.
Old Oct 18, 2014 | 07:12 PM
KsCop's Avatar
KsCop
Anyone ever use this one, or know how/where it attaches?
I can't locate it in the MPC (and yes, I finally got the MPC on CD)
Old Oct 20, 2014 | 05:30 PM
KsCop's Avatar
KsCop
Not a lot of traffic on this thread, so I'm guessing this is a rare topic (or wrong forum).
In any case, being a sucker for anything engine related, I bought the darn thing. Now I have it and can't figure out how / where to install it.
Anyone? Bueller? Bueller?
Old Oct 20, 2014 | 07:02 PM
Franklin2's Avatar
Franklin2
See if it lines up to the bolt spacing on the exhaust manifold. Sometimes they used long studs instead of bolts, and this bracket fit over the studs with nuts on the outside. If it doesn't line up to those, keep that same theme and see if it lines up with other threaded holes or bolts on the engine. To pick up a inline six, I would think you need to pick it up toward the rear and another spot toward the front.
Tugly
306
Jun 4, 2016 07:40 AM
KsCop
13
Oct 24, 2014 04:27 AM
lifted77f250
1983 - 2012 Ranger & B-Series
Mar 4, 2013 11:01 PM
Bdox
Ford vs The Competition
18
Jan 3, 2006 04:12 PM
mr4speedford
Jul 28, 2003 06:29 AM
