Lifting Lug
Old Oct 20, 2014 | 05:33 PM
KsCop's Avatar
KsCop
Lifting Lug
I saw a lifting lug on ebay. It said it attached to the cylinder head and was used to lift the engine. Supposedly a factory part.
Given my weakness for all things engine related and my upcoming engine swap, I bought the darn thing.
Now I can't figure out how to install it and if it is what they said it was
Any help?
Old Oct 21, 2014 | 12:44 PM
Mtphammer's Avatar
Mtphammer
Here is a pic of how mine is attached: http://i1288.photobucket.com/albums/...psq0q0lurq.jpg
Old Oct 21, 2014 | 04:16 PM
KsCop's Avatar
KsCop
Thanks VERY MUCH. Just what I was looking for.
A little hard to tell from the pic, but it looks like it attaches to the two studs in the head/manifold?
Mine has bolts instead of studs, but I'm thinking that's an easy fix..
Old Oct 21, 2014 | 04:24 PM
Mtphammer's Avatar
Mtphammer
Yes. The lifting lug uses the bolt/studs in the manifold. I used a kit of arp studs for a small block ford intake because the bolts are the same size. And btw you are very welcome. Anytime
Old Oct 21, 2014 | 04:38 PM
KsCop's Avatar
KsCop
Any chance you have the part number for the ARP kit?
Old Oct 21, 2014 | 06:18 PM
Mtphammer's Avatar
Mtphammer
Here is a link to them on summitracing:
http://m.summitracing.com/parts/arp-...03/none/images
Old Oct 22, 2014 | 09:52 AM
ZarK-eh's Avatar
ZarK-eh
That looks like it's mounted backwards, here's one mounted to an efi 4.9L... it's not a very good pic but kinda shows the big loop towards the front.
edit: kinda guessing it's mounted this way to clear the carb.
Last edited by ZarK-eh; Oct 22, 2014 at 09:55 AM. Reason: clear the carb, it's in the way!
Old Oct 22, 2014 | 10:06 AM
KsCop's Avatar
KsCop
It seems to me it would be better balanced with the 'big loop' more towards the center of the engine as in the first picture.
Hmm..
Old Oct 22, 2014 | 02:28 PM
Mtphammer's Avatar
Mtphammer
Originally Posted by KsCop
It seems to me it would be better balanced with the 'big loop' more towards the center of the engine as in the first picture. Hmm..
Yes. It is better balanced with the loop toward the rear. If you were to flip the hole towards the front, it would cause the balance to be off because there is a bend on the bottom of the lug so that it will be further toward the center of the engine. With the lug turned around, the engine will want to tilt at a 45 degree angle from side to side in addition to the normal tilt from front to back.
Old Oct 22, 2014 | 10:27 PM
ZarK-eh's Avatar
ZarK-eh
Yeah, I never used the lifting lug anyway as I went with a couple bolts on each end... Now I use it to grab onto when hauling my butt up into the engine bay.
I just know that with it forward is where it was on stock EFI'd 4.9L's. Although on a carb setup it would make sense to have it reversed and centre more.
Old Oct 22, 2014 | 10:39 PM
KsCop's Avatar
KsCop
two bolts on each end? Where?
I'm trying to find the best way to lift the engine out (and install the new one) with the transmission attached (4-speed)
Good lifting points are a must; hence the thought to use the lifting lug.
Old Oct 22, 2014 | 10:44 PM
Mtphammer's Avatar
Mtphammer
two bolts on each end? Where? I'm trying to find the best way to lift the engine out (and install the new one) with the transmission attached (4-speed) Good lifting points are a must; hence the thought to use the lifting lug.
I have used the lug to lift my engine that I converted from efi to carb with the zf five speed attached to it. You will be fine using the lug you have to lift your engine and trans combo.
Old Oct 22, 2014 | 10:47 PM
Mtphammer's Avatar
Mtphammer
Old Oct 24, 2014 | 04:27 AM
trozei's Avatar
trozei
Now I want one!
Most people just use two bolts though. One at the rear for the manifolds and one at the front for the coil. Here's mine.
tommylg
Mar 2, 2017 05:20 AM
KsCop
Oct 20, 2014 07:02 PM
fordbozo
Jul 6, 2012 09:02 PM
Joe_C
Jan 18, 2011 07:40 PM
twall_SD250
Modular V8 (4.6L, 5.4L)
Mar 8, 2010 08:29 AM
