Starter problem
Old 10-21-2014, 07:17 PM
53pickemuptruck's Avatar
53pickemuptruck
53pickemuptruck is offline
Gave it a try today ,just got finished and tried it , nothing happened . Think I might have it hooked up backwards. I've got 12 volts on the first battery cable hookup,but nothing going through to the other post. Just my luck .Try it again friday . If I don't have to work overtime. The Ford solenoid has two small posts not sure which to use for the 12 volt lead to the solenoid on the starter.
Old 10-21-2014, 07:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
The two small posts are usually marked "I" and "S". "I" is ignition, a connection that is only hot while cranking, usually only used with points that have a ballast resistor in the line. "S" is the wire from the starter button (12v).
The small terminal on your starter goes to the same big terminal on the solenoid as the big cable to the starter, if you are going to hook it up like I did.
Old 10-21-2014, 07:58 PM
53pickemuptruck
Thanks for the response , I'll check it out this weekend.
Old 10-24-2014, 05:55 PM
53pickemuptruck
Got to lookin at my Ford solenoid ,the plastic had a crack in it from the s terminal all the way up and it seperated from the metal bracket completely when I tugged on it. New one coming tomorrow. I had this one a couple years must have dry rotted.
Old 10-26-2014, 06:56 PM
53pickemuptruck
Finally got out to put the new solenoid on and give it a try. Worked every time now!!!! Thaks for the help ALBUQ F1 ,couldn't have got it without your help. Now on to the next problem. Hooking up my radiator fan to my Ron Francis Ice Box kit.
dcavan001
09-02-2017 10:36 AM
anied52
18
07-22-2016 04:56 PM
Daddywags
07-25-2008 07:54 AM
gollygwagen
13
05-22-2008 09:03 PM
Pete
08-04-2005 11:51 AM
Quick Reply: Starter problem
