Windshield wiper motor electrical
Old Oct 15, 2014 | 02:48 PM
drew1's Avatar
drew1
Hopefully someone can point me in the right direction. I have an '83 F100 that the wipers stopped working a couple weeks ago. The washer works, but not the wiper. I replaced the switch hoping that would be the problem, but it wasn't. I bought a new motor and plugged it in instead of out right replacing, and it didn't work either. So it sounds like wires to me. The switch is getting power since the pump works. I am looking for any suggestions. Thanks!
Old Oct 15, 2014 | 03:09 PM
Franklin2's Avatar
Franklin2
Check your grounding. Hook a wire to a good ground and touch it to the motor and see if it takes off.
Old Oct 15, 2014 | 03:21 PM
ctubutis's Avatar
ctubutis
Here ya go... this is in the archives and is available via searching this forum:
From the 1981 EVTM:
Old Oct 16, 2014 | 12:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different switches, with or without intermittent (delay) wipers.
If your truck has intermittent wipers, it also has an intermittent wiper governor.
The right and left wiper arms connect to the motor w/a clip (17531). If the clip breaks or falls off, the arms may be disconnected from the motor.
Lower pic:
Old Oct 20, 2014 | 11:30 AM
drew1's Avatar
drew1
Thanks for all the information! Just to close the loop, I replaced the wiper motor over the weekend. The old one was dead. I had forgotten to ground the new motor after plugging it in to verify that it worked. As soon as I added a ground the motor turned over. The hardest part of this project was getting the cowl off so that I could access the motor and the wiper linkage. I've got to paint some areas that got scratched while removing the cowl, but that is why I used an enamel paint. The wipers now work like a champ! Thanks for the assistance.
truck157
1997 - 2003 F150
Jul 20, 2021 08:08 AM
Kemicalburns
1978 - 1996 Big Bronco
Feb 23, 2017 07:23 PM
Whisk3y
2004 - 2008 F150
Jun 8, 2016 03:32 PM
55coe
Dec 17, 2013 12:49 PM
HUNTER10
Mar 4, 2007 04:39 PM
