Column vs Dash key. Pros and Cons?
Old Oct 16, 2014 | 09:59 PM
clintonvillian's Avatar
clintonvillian
How hard is it to convert the automatic GM columns to a floor shift?
Old Oct 19, 2014 | 04:15 PM
petemcl's Avatar
petemcl
A medium-sized screwdriver works on GM columns.
Old Oct 19, 2014 | 05:05 PM
mytbtruck's Avatar
mytbtruck
I used a column from a 1989 S10 and cut the gear shift **** out and used bondo to fill the hole. Sanded it down even and you cannot tell it ever had a gear shift lever in the column. Best if you could find a Blazer or S10 with a floor shift at a junk yard. It would have a column without any thing to deal with. If you used an EZ wiring harnes it is very easy to wire lights, turn signals and ignition switch with this column. Several other year columns would be the same. It is also very easy to replace the lock cylinder and it is abot 10-15 dollars. I paid 50 dollars for mine with the steering wheel on it.
Old Oct 19, 2014 | 05:13 PM
mytbtruck's Avatar
mytbtruck
I made the mount to bolt under the dash and onto the column with the original bolts.
marine1200
1947 and Older Ford Trucks
Feb 8, 2012 08:21 PM
1bigjoe
19
Jan 29, 2012 10:12 AM
kawa
Nov 7, 2007 10:05 PM
Marc150
Jun 20, 2004 10:01 PM
jj292
Dec 23, 2003 04:13 PM
