Factory tach from hell
So I decided to replace the entire green wire that leads from the coil to the plug since the previous wire was burned slightly.
Here you can see my very nice shrink wrapped connections I made. I used 14 gauge oil and gas resistant insulated wire from home depot.
I decided to pick up some CRC contact cleaner from home depot while I was there. Worked rather well cleaning the connections.
These are the two connections that I cleaned.
I used some dielectric grease on the connections.
Heres the connections I applied the grease to.
Also most importantly added the grease to these connections.
Connections all plugged back up.
Got all the tools together to work on the instrument panel.
For everyone that is concerned, here is the circuit board.
After removing the tach, here are the connections that the tach connects to.
Nice picture of the PCB of the tach, you can see the areas that were scraped earlier to remove the gunk.
Everything seemed to be fine.
Another picture.
Yet another.
Here is the reverse side, checked for cold joints, did not see any.
Another picture.
Decided to clean off some gunk that may be under the components with some compressed air.
After a dusting, removed all the nasty gunk.
As you can see, everything seems to be in order.
No problems that I can see.
There was only this one section between the capacitor and resistor that was in question.
Another image of the PCB and the previous cleaning that took place.
everything seems to be in working order.
Looks good, about to put the cover back on the tach now.
Pulled out the rubbing alcohol to clean connections.
Cleaned the connections on the PCB for the tach.
Also cleaned the nuts that attach electrically to the PCB.
Put a thin layer of dielectric grease on the contacts.
Since the instrument panel was already out, I decided to paint the needles. I used some enamel paint for model cars in florescent orange.
The needles look really nice with the coat of enamel on them.
I cleaned the contacts and then put a thin layer of dielectric grease on the contacts.
As you can see, the tach worked after all that work, thank goodness.
*UPDATE* started the truck up later that night to go to the store and.... NO TACH!! ughhhh
Then this happens, the last photo was taken at 2129, and then this photo was taken at 2145. I am really at a loss here. It hasent died on me afterwards, I started the truck and cut it off 3-4 times after, and it stayed on, but who knows for how long. I wasent kidding when I said its the factory tach from hell. ughh I appreciate you all for helping me out with this.
A common use of dielectric grease is in high-voltage connections associated with gasoline engine spark plugs. The grease is applied to the rubber boot of the plug wire. This helps the rubber boot slide onto the ceramic insulator of the plug. The grease also acts to seal the rubber boot, while at the same time preventing the rubber from becoming stuck to the ceramic. Generally spark plugs are located in areas of high temperature, and the grease is formulated to withstand the temperature range expected. It can be applied to the actual contact as well, because the contact pressure is sufficient to penetrate the grease. Doing so on such high pressure contact surfaces between different metals has the advantage of sealing the contact area against electrolytes that might cause rapid galvanic corrosion.
Also, when cleaning those connections and the ones under the nuts I like to use a pencil eraser. But you have to use it gently as the copper traces can be pulled loose. And that's where I really like the copper-filled anti-seize as it completes the circuit as prevents oxidation.
Edit: I forgot to say that I think some of those solder joints could be cold. But the pic wasn't focused in all areas so I really couldn't tell.
Good job on ridding the brown crud off the circuit board. Where the lugs attach to the PCB looks like a cold joint is forming. You see the solder flux is a ring around the posts , that is a weak joint there.
I would of re soldered the whole PCB while I had it out. It helps as there are cold joints forming that you do not see.
One way to find out if the tach is bad or a wiring is the issue is to hook up a aftermarket tach directly to the back side of the factory tach. With both tachs getting signal from the same wires, I quickly found my tach problem on my truck, the after market worked fine while the factory tach went nuts...
ALSO, I was wondering, is there any documentation out there for electrical schematics for the PCB of the tach?? Im sure its a long shot but does not hurt to ask.
In response to the grease complaint, I would like to quote someone in the field of electronics below.
From (Dielectric Grease vs Conductive Grease)
"The word dielectric is assumed to mean the connection will have future problems because "dielectrics" are insulators. Generally, authors predict greases with powdered metal (in slang "conductive greases") will improve or maintain connection quality over time while dielectric greases will isolate connections because "that is what dielectrics do". ///break/// I continue to use silicone dielectric grease today. I use it as a lubricant on coaxial connector O-rings and threads. I use it to lube stainless bolts and nuts, to prevent galling. I use it for plug-in connections, in particular in my automotive hobby. I also use silicone dielectric grease for battery terminal connection preservation, coating it directly on the battery post. I use it in liberal amounts on ground connections, to inhibit corrosion on stainless-to-zinc (galvanized), lead-to-lead, stainless-to-copper, and stainless-to-aluminum electrical connections. ///break/// I have never found a problem with silicone dielectric compound increasing resistance or increasing wear. We use it in new equipment production to lubricate and preserve contact plating in very low current meter switches."
Thank you everyone for the input, and I will have to purchase myself a soldering gun and solder to resolder the board later this weekend. I really appreciate everyone here, Thank you.
However, I do agree that you have a problem with the PCB or the associated solder joints. Expansion and contraction seem to be causing the disconnect.
Also, I'm not aware of any schematic for the tach.
Thanks for the input theguruat12, I am going to give this a try before I start the lengthy process of re-soldering the entire PCB to see if that solves the problem, and I will keep everyone informed.
