Sponsored by: Real Truck
What Brand Multimeter do you use?
Old Oct 13, 2014 | 05:35 PM
Firefighter 1406's Avatar
Firefighter 1406
I had a nice Sunpro multimeter since I graduated and has given me great service until last week. It died on me. Checked the batteries and fuses to no avail. So I am in the market for a new multimeter, was looking at a Fluke 115. I can get a new one off eBay for around $100. But want to get your guys opinions, what meters do you guys use and why?
Old Oct 13, 2014 | 06:11 PM
Ferguson65's Avatar
Ferguson65
I have a Fluke 88. But I'm a heavy equipment mechanic and use it all the time. It has not been given an easy life. 4 years at a car dealer, 2 years in a heavy equipment shop, and 6 years in a heavy equipment field service truck. It's been dropped, abused, exposed to the elements, heat, cold everything. I try my best to keep it out of the rain and such, but it's happened. I can't believe its really 12 years old. Still works great and going strong. It was expensive, around $600 I think, but lasting 12+ years justifies the price IMO. I have no doubt that one for occasional (homeowner) use would last nearly forever.
Old Oct 13, 2014 | 06:59 PM
Firefighter 1406
I saw the 88. Man that thing is expensive. That did everything and more that my Sunpro did. Do you have any experience with the fluke 115B+ ?
Old Oct 13, 2014 | 07:19 PM
Good_ol_boy's Avatar
Good_ol_boy
My nice one is a Fluke, but I keep a cheap Gardner Bender in my toolbox, both work pretty well. I believe my fluke is the 115
Old Oct 13, 2014 | 07:58 PM
Just Strokin's Avatar
Just Strokin
most cases at home a cheap Radio Shack will serve the purpose.....i have used one for many years....has done ever check i needed...
Old Oct 13, 2014 | 09:17 PM
The Kaz's Avatar
The Kaz
I have a Fluke 77 at home and newer one at work with a current clamp. Can't work without it !!
Old Oct 14, 2014 | 12:01 AM
Yahiko's Avatar
Yahiko
Fluke.
Need I say more?
Sean
Old Oct 14, 2014 | 12:05 AM
Skip1970's Avatar
Skip1970
i run a couple craftsmans, one with the amp clamp and one without. i suggest what ever you get make sure it has amp clamp as that is great for finding battery drainers
Old Oct 14, 2014 | 01:55 AM
JSchuricht's Avatar
JSchuricht
I used to have a Wavetek that was fully manual, none of the auto ranging stuff most new ones have but after 10 years it started giving me phantom readings. I replaced it with a collection of Fluke meters. For most stuff I used a Fluke 233a which is 4 digit with a detachable wireless display. Its great for working on the truck or checking for voltage at the trailer lights without a helper. For other measurements I use a Fluke 123s which is their cheep ($1500) portable o-scope. I also have a Fluke clamp that can hook up to either meter, I think its a i410 but its not near by right now.
Old Oct 14, 2014 | 05:19 AM
Gunny Mike's Avatar
Gunny Mike
Veteran: Marine Corps
I have a Fluke and a Craftsman. The Fluke is exceptionally durable and can take punishment and hold up. The Craftsman is fine for the occasional use around the house and is fairly inexpensive. The Fluke is normally much more expensive, but worth it if you use it often and want to have it for years to come. Either way, invest in the amp clamp to go with it.
Gunny Mike
Old Oct 14, 2014 | 05:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
For the majority of automotive use, a cheap HF analog multimeter will work OK. A lot of times you can get them free. They often do not survive being beaten around in the tool box, but they are basically worth what you pay for them.
If you want something with a little more precision and durability, Fluke is a highly recommended brand, but you're going to drop a few hundred dollars on a good meter. Multimeters sensitivity is rated by "ohms per volt". The more ohms the better.
Old Oct 14, 2014 | 07:56 AM
Firefighter 1406
Sorry, double post
Old Oct 14, 2014 | 07:57 AM
Firefighter 1406
This is the meter I have been looking at. You Fluke guys are all the meter capatable with a amp clamp? Or should I just get an amp clamp multimeter? Are there pros and cons to both?
http://m.ebay.com/itm/380983187121?nav=SEARCH
Old Oct 14, 2014 | 08:01 AM
acf6's Avatar
acf6
^ That one is nice, i have 3 fluke meters but im in electrical work so ive just had them with me. I actually have a cheap autozone meter in my truck that bounces around the tool box lol
I would get one with a seperate amp clamp, one of my meters has the amp clamp built into it but it doesn't work so well on my truck because i cant fit it around anything...if i had just the lead with the clamp i could
Old Oct 14, 2014 | 08:10 AM
Firefighter 1406
That's kinda what I figured to. I have a cheap craftsman that goes in the truck. This will be the garage meter. Those amp clamps are freaking pricey. But I guess soon as it says Fluke there goes another $50.
